Aspire 3680 Mouse Driver Issues
Discussion in 'Acer' started by krazyphire, Jun 23, 2007.
  1. krazyphire
    krazyphire Notebook Consultant
    I'm trying to uninstall the driver (Synaptics) for the mouse on my Aspire 3680 Windows XP Professional. Everytime I uninstall the driver I'm asked to restart the computer and when I do windows xp claims that it finds new hardware (mouse) and it needs to restart to install the driver. The problem is that when it restarts the driver that was giving me problems is the one that it installs. I need help to stop win xp from automatically installing drivers.
    PS: The problem with the driver is that it locks up the mouse sometimes and makes it so that I can't drag folders with the left click/touchpad combo.
  2. Hairy_Lee
    Hairy_Lee Notebook Consultant
    you should be able to download the latest synaptics driver and just over install the old one.
    However, i've not seen this on machine before and i think its therefore more likely to be a hardware fault than anything else.
  3. krazyphire
    I already tried reinstalling the driver and I guess it must be some setting in the driver because the mouse continued to malfunction. Also it can not be a hardware malfunction because when I uninstalled the synaptics driver it started to work perfectly. That is when windows told me to restart so that it could reinstall the driver.
  4. Evolution
    Evolution Vox Sola
    I had the same issue with my 5102 that you described a few weeks back but in my case when I uninstalled the synaptics driver, windows never tried to reinstall it.
    This occurred to me as well because my touchpad works flawlessly now without the aid of any synaptics drivers, all it is using now is the default Microsoft PS/2 mouse driver. I suppose that somewhere in windows the synaptics driver is somehow corrupted and no matter whether I used the one from acer or the one from synaptics website none would work! Most likely a fresh install of windows might fix this problem as it is clearly not a hardware fault.
  5. krazyphire
    Outside of a full file repair from the windows xp disk, can I somehow disable windows from automatically installing drivers for new hardware. Also when I start up the installation disk would I use boot from cd so that it repairs an existing windows installation?
  6. krazyphire
    Help Please, How do I turn of the function that makes it so that XP automatically reinstalls drivers?
