ASIC quality reference
Discussion in '2015+ Alienware 13 / 15 / 17' started by judal57, Jul 20, 2016.
  1. judal57
    judal57 Notebook Deity
    I want to know the Asic quality of your graphics card to have a reference ... here is mine gtx 970m
    you can use gpuz to check it
  2. DeeX
    DeeX THz
    Broken picture
  3. judal57
    is fine
  4. DeeX
    DeeX THz
    Ah, indeed it works now. Before it was not showing. :)
  5. judal57
    post your Asic quality ¬_¬
  6. VICKYGAMEBOY
    VICKYGAMEBOY Notebook Deity
    im reinstalling insider build, i cant send u screenshot, but im 100% sure, its same as urs.. 70.9%.. my previous R1 had 78%.. both had same GTX 980M.. R1 with 4GB, R2 with 8GB..
  7. judal57
    i am thinking on be an insider too, but i don't know if this come with issues .... what can i expect ?
  8. VICKYGAMEBOY
    i've been insider for past 6 years.. so i love to check new stuffs, also i have backup systems.. so i dont mind.. if u have backup system sure u can try.. offcourse, tons of bugs, new feautures, driver conflicts will be there.. anyways Windows 10 Redstone Build Releasing August 2nd, so its almost there. just wait and install the RTM version..
  9. judal57
    thanks ... i am going to wait ...
  10. Plur
    Plur Notebook Consultant
    GTX 970M (Clevo)
    68.3%
    judal57 likes this.
