AS5 what did I do wrong
Discussion in 'Hardware Components and Aftermarket Upgrades' started by usmc1488, Oct 27, 2010.
  1. ScreenSaver
    ScreenSaver Notebook Consultant
    I put Antec Formula 5.. that ok? or should I change it? If you really think I should.. what to use ?:) Thanks!
    M11x.
    ps. I have tried to post photos so you can see it in my text instead of clicking a link.. I simply don't know how:(
    Quote by usmc1588:
    So I added as5 to my 2 gpu's and one didnt have a reduction in temps and the other had an increase. I prepped the gpu's and fans by scraping the old paste off followed by using alcohol. Was I supposed to wait a certian amoumt of time for it to dry?
    Unquote.
    When I removed mine.. it was kind of like playdoh. wasn't messy.. too dry. I used a credit card to scrape it off. I removed.. used 91% Isopropyl alachol.. Q-tips!.. Then I applied with my finger in a plastic bag snugly wrapping around my finger for a total smooth finger tip ( Only about 4 inch square of the bag to cut out to do this NOT the entire bag ).. this way it rubs on and applys nicely.. ( saw this in a 'apply thermal grease guide' ) . Some say to apply on the heat sinc then whipe it off with a cloth leaving the stain.. but apply on the CPU / GPU and lower the cooler.. ( This also was read from a 'apply thermal grease guide' )... this fills the micro cracks of scratches you caused . I also read.. less is more. You don't want it to ooze out the sides.
    I use a grounding strap when I do this. Always.
    It is true.. it takes time to ' cure '
  2. usmc1488
    usmc1488 Notebook Evangelist
    Ive been using gpu-z to accurately monitor temps, ive seen 97 c is this too hot for the 9800m ? A new driver and as5 has lowered it to 90. Whats the safe operating temp range?
  3. jeremyshaw
    jeremyshaw Big time Idiot
    Anything under 105C.
    Though I find 90C too hot. 80C is where I feel more comfortable. But that's just me.
  4. inap
    inap .........................
    if your temps are good then leave it. some good paste are mx-3, ocz freeze, shin-etsu, also mx-4 is out and heard it is good also but haven't had the chance to try it yet.
    yes some paste needs curing time, like as5 need 200 hrs. but i perfer using the above mentioned paste because it non conductive and has no curing time.
  5. usmc1488
    inap, does 90 look like a good temp to you? Whats in your opinion a good heat range for Nvidia cards?
  6. usmc1488
    ps thanks everyone for the input and advice, just trying to keep my investment alive!
  7. inap
    90 is consider alittle high but still safe, i would try to get it under 85 for max.
  8. SillyHoney
    SillyHoney Headphone Enthusiast
    My old GTX 260M SLI and new XFX 5870M never reach 80C in any circumstance. And I don't know how to apply paste by the way.
  9. steviejones133
    steviejones133 Notebook Nobel Laureate
    Wow - does that include furmark? - ive been running my stock system test using furmark multigpu with factory pastes still on and my temps in furmark top out at 89/90c as a rule, run for 5 mins on xtreme burn in 1920x1080 etc....
  10. lidowxx
    lidowxx Notebook Deity
    97 c is definitely too high for a 9800M, 90C is not healthy either in the long run, have you considered investing in a laptop cooler? Also other paste like ICD-7 will give you better result than AS5. My laptop cooler(zalman nc2000) along with ICD-7 helps lowering the temp of my 9800M gs a lot, it always stays under 80C.
    If you want to keep your laptop running for a few years, you'd better keep the GPU under 85 C.
