Area-51 m15x HDMI problem.
Discussion in 'Alienware' started by Mazdaspeed_6, Dec 4, 2009.
  1. Mazdaspeed_6
    Mazdaspeed_6 Notebook Evangelist
    i can't get the HDMI to work with a HDTV LCD. i'm not in stealth mode, and i am using the 8800m GTX. when i connect it, i hear the windows connection sound. and sound transfers but i don't see anything, it is completely black on both the laptop screen and the HDTV. any idea what's going on?
  2. Matrolz
    Matrolz Notebook Guru
    Try Fn+F6. Also, try with another HDMI TV if you have one
  3. XenoPhoenix
    XenoPhoenix Notebook Enthusiast
    Also just a tip make sure you are plugging the computer into the correct hdmi slot on the tv, some tv's have two and one is meant for pc's the other for everything else it seems like. Also is the checkmark for extend monitor checked in your display settings.
  4. Mazdaspeed_6
    tried it. got 2 40ins and a 52 in. none work.
  5. Mazdaspeed_6
    my m17x works with all the HDMI ports on the HDTVs. and i can't check mark the extend monitor because my laptop screen turns off when HDMI is hooked up.
  6. Matrolz
    Well, seams like it's something with the laptop. If it's not driver problems then I don't know what
  7. Mazdaspeed_6
    i'm gona just get it diagnosed from a comp tech. thanks guys.
  8. dwend
    dwend Notebook Evangelist
    get the nvidia 186.61 driver
  9. Mazdaspeed_6
    got those. same issue with every driver.
  10. CitizenPanda
    CitizenPanda Notebook Deity NBR Reviewer
    It's your HDMI cable. If you spent $3 on it, now you know why it only cost $3.
