Are internal GPS' the same in CF-18 and CF-19?
Discussion in 'Panasonic' started by azTony, Apr 13, 2013.
  1. azTony
    azTony Notebook Consultant
    I was looking to upgrade to a newer CF-19 and use the internal GPS from my CF-18 in the CF-19. I could not find if they are interchangeable or not. :confused:
  2. toughasnails
    It does sound like a good idea but I have read on here that it will not fit...sorry
  3. Shawn
    Do you mean the separate gps or the one integrated with the WWAN?
  4. azTony
    I did not know there was one integrated with the WWAN. Actually... I have not had a chance to look into what WWAN really is.
    I have a CF-18 and just bought a CF-19 MK3, I wanted to swap out the GPS from the CF-18 into the CF-19 but with the post above I went ahead and bought a CF-19 with an internal GPS. I will be posting up asking the value of my current CF-18 that I will be posting up on eBay.
