***Aorus X7 Pro owner's lounge***
Discussion in 'Gigabyte and Aorus' started by cookiesowns, Dec 15, 2014.
  1. Damin
    Damin Notebook Consultant
    1. Clean everything off with IPA
    2. Clamp the 2 heatsinks together i used MX2 between them and bond with epoxy , Make sure everything lines up 100% with all screw holes otherwise you will need to start over !( the steal epoxy will be better i think but this works for now )
    3. Replace all the heat pads i bought 1MM and 0.5MM ( i only used the 1MM )
    4. Apply thermal paste i used MX2 but will maybe try GELID EXTREME next some time
    5. Put everything back together and run a good few tests after about 2 hours everything should settle and temps should stabilize <3 20180425_122406.jpg 20180425_122429.jpg 20180425_122450.jpg 20180425_122500.jpg 20180425_122509.jpg
  2. Damin
  3. Damin
    i hope this helps some people if they have this unit like me ..
    i restore Clevo laptops and thought let me take a chance on this one i have learnt loads thank you AORUS X7 PRO
    PS: Temps on the CPU are a solid 8 degrees down and both GPU's are around 10 degrees down on each
  4. Damin
  5. Damin
    Good morning all ... Can anyone confirm if the 2 GPU's have same VBios or like mine in the image?
  6. GTVEVO
    GTVEVO Notebook Deity
    Looks like two different vbois versions to me, the question is was this done on purpose by the vendor or not.
  7. Damin
    I think it was ... but I can only speculate this .
    I can not seem to find anything on them on the net
    GTVEVO likes this.
  8. GTVEVO
    I would agree as it would make sense to regulate the power/heat to meet the cooling solution requirements.
    Hopefully some other pro owners will share and shine some light soon.
