Aorus X7 DT V8 Current Limit Throttling Constantly down to 15 Watts... thoughts?
Discussion in 'Gigabyte and Aorus' started by GizmoSlip, Jul 25, 2018.
  1. GizmoSlip
    GizmoSlip Notebook Deity
    I wasn't having any issues with this Aorus X7 DT V8 until I ticked the "Power Saving" check box in the windows 10 pop up box. After ticking it, constant power throttling is occuring, as if Windows is trying to save electricity and is trying to save battery life increasing clock speed.
    Any thoughts on disabling this throttling? I've restarted. I've tweaked settings in Intel XTU. I've set new OC profiles in Aorus Command and Control. Thoughts?
    I was hitting constant 4.3 ghz with 101 Watts throughput before this foopa.
    EDIT: I may have fixed it by editing my registry to prevent Windows 10 Power Throttling. Seems that it may have gone away. Going to do more testing.
    EDIT: That didn't fix anything.
    EDIT: Throttlestop seems to have overridden any throttling settings the Intel XTU was failing to address. Interesting. TS for the WIN!
  2. GizmoSlip
    But the only problem is that Aorus control software utilizes and sets up its OC using Intel XTU, which conflicts with the TS. Not sure how to best approach that. Probably just remove Intel XTU and the Aorus CC software will be broken?
    Vistar Shook likes this.
  3. GTVEVO
    GTVEVO Notebook Deity
    You might just try to remove the XTU profiles from the application. On the X7 V7 they are located at C:\Program Files\AORUS\SmartManagerV3\cpuoc\X7Y7 directory you will see files with the .xtu extension. Do a search for *.xtu find your directory, back it up and remove them. Reboot and see how it behaves.
    I am not surprised to see Throttle stop answer your needs as its a very good and useful tool. Please donate to it and keep it going if possible. Something is better than nothing, thanks.
    Darkhan and Papusan like this.
  4. Mattant
    Mattant Newbie
    Hey mate, sorry for the thread resurrection. JUst wondering what setting you use to hit 4.3 constant? I cant seem to keep 3.9 constant let alone 4+
    Cheers!
    Matt
