Aorus 15p I7 10th gen 3070 Micro Stuttering issue
Discussion in 'Gigabyte and Aorus' started by Dennis1998, Jun 10, 2021.
  1. Dennis1998
    Dennis1998 Newbie
    Yesturday I got brand new laptop and I am experincing micro stuttering isues with the windows system i.e luching apps animnation is lagging sometimes, other time workks fine. No graphics issue, and systems seems fine. Also the ACPI.sys seeems causing the issue
    I have ran Latency mon app and the results are the following. If somebody had such issue, please let me know, will be really helpful!
    _________________________________________________________________________________________________________
    CONCLUSION
    Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too
    long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
    LatencyMon has been analyzing your system for 0:01:55 (h:mm:ss) on all processors.
    SYSTEM INFORMATION
    Computer name: DESKTOP-95SSC5K
    OS version: Windows 10, 10.0, version 2009, build: 19042 (x64)
    Hardware: AORUS 15P XC, GIGABYTE
    CPU: GenuineIntel Intel(R) Core(TM) i7-10870H CPU @ 2.20GHz
    Logical processors: 16
    Processor groups: 1
    RAM: 32640 MB total
    CPU SPEED
    Reported CPU speed: 2208 MHz
    Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
    MEASURED INTERRUPT TO USER PROCESS LATENCIES
    The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an
    event and the waking up of a usermode thread from an idle wait state in response to that event.
    Highest measured interrupt to process latency (µs): 1500.40
    Average measured interrupt to process latency (µs): 3.844256
    Highest measured interrupt to DPC latency (µs): 1460.60
    Average measured interrupt to DPC latency (µs): 1.833345
    REPORTED ISRs
    Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
    Highest ISR routine execution time (µs): 508.424819
    Driver with highest ISR routine execution time: ACPI.sys - ACPI Driver for NT, Microsoft Corporation
    Highest reported total ISR routine time (%): 0.004129
    Driver with highest ISR total time: ACPI.sys - ACPI Driver for NT, Microsoft Corporation
    Total time spent in ISRs (%) 0.006507
    ISR count (execution time <250 µs): 28717
    ISR count (execution time 250-500 µs): 0
    ISR count (execution time 500-1000 µs): 17
    ISR count (execution time 1000-2000 µs): 0
    ISR count (execution time 2000-4000 µs): 0
    ISR count (execution time >=4000 µs): 0
    REPORTED DPCs
    DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
    Highest DPC routine execution time (µs): 2482.397645
    Driver with highest DPC routine execution time: ACPI.sys - ACPI Driver for NT, Microsoft Corporation
    Highest reported total DPC routine time (%): 0.024910
    Driver with highest DPC total execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
    Total time spent in DPCs (%) 0.097090
    DPC count (execution time <250 µs): 211737
    DPC count (execution time 250-500 µs): 0
    DPC count (execution time 500-10000 µs): 1107
    DPC count (execution time 1000-2000 µs): 13
    DPC count (execution time 2000-4000 µs): 6
    DPC count (execution time >=4000 µs): 0
    REPORTED HARD PAGEFAULTS
    Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and
    blocked from execution.
    NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
    Process with highest pagefault count: zoom.exe
    Total number of hard pagefaults 896
    Hard pagefault count of hardest hit process: 264
    Number of processes hit: 19
    PER CPU DATA
    CPU 0 Interrupt cycle time (s): 5.726787
    CPU 0 ISR highest execution time (µs): 508.424819
    CPU 0 ISR total execution time (s): 0.116453
    CPU 0 ISR count: 26436
    CPU 0 DPC highest execution time (µs): 2482.397645
    CPU 0 DPC total execution time (s): 1.633981
    CPU 0 DPC count: 190068
    CPU 1 Interrupt cycle time (s): 2.213250
    CPU 1 ISR highest execution time (µs): 122.766304
    CPU 1 ISR total execution time (s): 0.002996
    CPU 1 ISR count: 1983
    CPU 1 DPC highest execution time (µs): 717.167572
    CPU 1 DPC total execution time (s): 0.080281
    CPU 1 DPC count: 6727
    CPU 2 Interrupt cycle time (s): 1.631096
    CPU 2 ISR highest execution time (µs): 122.483696
    CPU 2 ISR total execution time (s): 0.000364
    CPU 2 ISR count: 315
    CPU 2 DPC highest execution time (µs): 417.692029
    CPU 2 DPC total execution time (s): 0.035830
    CPU 2 DPC count: 7680
    CPU 3 Interrupt cycle time (s): 1.581833
    CPU 3 ISR highest execution time (µs): 0.0
    CPU 3 ISR total execution time (s): 0.0
    CPU 3 ISR count: 0
    CPU 3 DPC highest execution time (µs): 28.337862
    CPU 3 DPC total execution time (s): 0.000397
    CPU 3 DPC count: 137
    CPU 4 Interrupt cycle time (s): 1.470624
    CPU 4 ISR highest execution time (µs): 0.0
    CPU 4 ISR total execution time (s): 0.0
    CPU 4 ISR count: 0
    CPU 4 DPC highest execution time (µs): 496.231884
    CPU 4 DPC total execution time (s): 0.011611
    CPU 4 DPC count: 2505
    CPU 5 Interrupt cycle time (s): 1.472027
    CPU 5 ISR highest execution time (µs): 0.0
    CPU 5 ISR total execution time (s): 0.0
    CPU 5 ISR count: 0
    CPU 5 DPC highest execution time (µs): 113.068841
    CPU 5 DPC total execution time (s): 0.000836
    CPU 5 DPC count: 162
    CPU 6 Interrupt cycle time (s): 1.380630
    CPU 6 ISR highest execution time (µs): 0.0
    CPU 6 ISR total execution time (s): 0.0
    CPU 6 ISR count: 0
    CPU 6 DPC highest execution time (µs): 233.625906
    CPU 6 DPC total execution time (s): 0.005251
    CPU 6 DPC count: 1374
    CPU 7 Interrupt cycle time (s): 1.368580
    CPU 7 ISR highest execution time (µs): 0.0
    CPU 7 ISR total execution time (s): 0.0
    CPU 7 ISR count: 0
    CPU 7 DPC highest execution time (µs): 63.411232
    CPU 7 DPC total execution time (s): 0.000125
    CPU 7 DPC count: 24
    CPU 8 Interrupt cycle time (s): 1.265885
    CPU 8 ISR highest execution time (µs): 0.0
    CPU 8 ISR total execution time (s): 0.0
    CPU 8 ISR count: 0
    CPU 8 DPC highest execution time (µs): 123.269928
    CPU 8 DPC total execution time (s): 0.003519
    CPU 8 DPC count: 1131
    CPU 9 Interrupt cycle time (s): 1.356971
    CPU 9 ISR highest execution time (µs): 0.0
    CPU 9 ISR total execution time (s): 0.0
    CPU 9 ISR count: 0
    CPU 9 DPC highest execution time (µs): 83.322464
    CPU 9 DPC total execution time (s): 0.003111
    CPU 9 DPC count: 1340
    CPU 10 Interrupt cycle time (s): 1.386595
    CPU 10 ISR highest execution time (µs): 0.0
    CPU 10 ISR total execution time (s): 0.0
    CPU 10 ISR count: 0
    CPU 10 DPC highest execution time (µs): 120.940217
    CPU 10 DPC total execution time (s): 0.002419
    CPU 10 DPC count: 396
    CPU 11 Interrupt cycle time (s): 1.470829
    CPU 11 ISR highest execution time (µs): 0.0
    CPU 11 ISR total execution time (s): 0.0
    CPU 11 ISR count: 0
    CPU 11 DPC highest execution time (µs): 143.179348
    CPU 11 DPC total execution time (s): 0.001639
    CPU 11 DPC count: 159
    CPU 12 Interrupt cycle time (s): 1.293302
    CPU 12 ISR highest execution time (µs): 0.0
    CPU 12 ISR total execution time (s): 0.0
    CPU 12 ISR count: 0
    CPU 12 DPC highest execution time (µs): 142.642210
    CPU 12 DPC total execution time (s): 0.002688
    CPU 12 DPC count: 437
    CPU 13 Interrupt cycle time (s): 1.354614
    CPU 13 ISR highest execution time (µs): 0.0
    CPU 13 ISR total execution time (s): 0.0
    CPU 13 ISR count: 0
    CPU 13 DPC highest execution time (µs): 628.632246
    CPU 13 DPC total execution time (s): 0.001541
    CPU 13 DPC count: 66
    CPU 14 Interrupt cycle time (s): 1.180649
    CPU 14 ISR highest execution time (µs): 0.0
    CPU 14 ISR total execution time (s): 0.0
    CPU 14 ISR count: 0
    CPU 14 DPC highest execution time (µs): 109.144928
    CPU 14 DPC total execution time (s): 0.002467
    CPU 14 DPC count: 321
    CPU 15 Interrupt cycle time (s): 1.273897
    CPU 15 ISR highest execution time (µs): 0.0
    CPU 15 ISR total execution time (s): 0.0
    CPU 15 ISR count: 0
    CPU 15 DPC highest execution time (µs): 135.738225
    CPU 15 DPC total execution time (s): 0.001971
    CPU 15 DPC count: 336
  2. seba84_2005
    seba84_2005 Notebook Consultant
    You have problem with:
    My aorus 15P XC after playing rdr2:
  3. Dennis1998
    Dennis1998 Newbie
    What I have noticed, is when you select an external display and turn off main one, such issue occurs. When I have two displays on the issue disapears. Although as short time fix, this solved the issue. I have to keep looking addtionaly. On top of that, it selects wierd blue fix, had to disble v sync fot that. Tried both mini display and hdmi ports. The issue both occurs with and without zoom.
  4. seba84_2005
    Switch in bios gpu to NVIDIA.
  5. Dennis1998
    Dennis1998 Newbie
    I'll try, hopefulyy that would fix the problem
  6. Dennis1998
    Dennis1998 Newbie
    Work's like a charm, many thanks for the help
    seba84_2005 likes this.
