anyways to force crysis to run in a resolution lower than 800x600
Discussion in 'Gaming (Software and Graphics Cards)' started by umar, Apr 20, 2008.
  1. umar
    umar Notebook Evangelist
    i wanna run it in like 640x480 so that i can end in once in Very High...right now i get abt 17-18 avg FPS in very high 800x600 which is the lowest res available in the options:D
  2. Nocturnal310
    Nocturnal310 Notebook Virtuoso
    Safe mode..Keep CTRL pressed while Launching the game.
    but u have 8800m GTs... why are u running that beautiful game on 800X600 i dont know.
  3. 660hpv12
    660hpv12 Notebook Deity
    i think running native res on low look a lot better than 640x480
    I dont dare to run crysis but its generally true for all games
  4. jeopardy2k8
    jeopardy2k8 Notebook Consultant
    what, 17-18fps isn't enough for you?!
  5. Charles P. Jefferies
    Charles P. Jefferies TG Lead Moderator Super Moderator
  6. umar
    well i run it in 800x600 cuz in the later stages....specifically the last one on the carrier the game runs real choopy...i think even at 800x600 avg fps at high setting is like 15-16 and very high is like 5-6....so i run it in windowed mode so although everything is very small i dont think the visual quality suffer but fps increase
  7. umar
    man Chaz can u help me...this tweakguide website u said abt aint opening up...its giving an HTTP 500 internal server error????:confused:
  8. RunKhrinD
    RunKhrinD Notebook Enthusiast
    Try the natural mod, you should be able to emulate very high with only the demand of high settings.
  9. eleron911
    eleron911 HighSpeedFreak
    There is a setting in the Nvidia Control Panel, called Manage Custom Resolutions.
    Click Create,then Test,Ok, then you`re all set.
    I play Assassin`s Creed at 1066x600 in order to play at 16:9 aspect ratio, max details and shadows so that I always get OVER 20 fps(when it dipps at the synchronization points),averaging 30.
    I also played Crysis and Unreal Tournament 3 at 960/600(basically a quarter of my native resolution) at all high , respectively 5/5 details and got over 25 fps(crysis), respectively 60 fps constant(Ut3).
    I`d rather play at a lower res and get the max details than play native and all low or medium. Unless it`s an older game .
    I`m a fps freak, if I don`t get over 25-30 fps in a game, I lower resolution as much as possible,and increase AA to compensate.
  10. umar
    thanks eleron
