Anyone added WWAN to a P870 chassis?
Discussion in 'Sager and Clevo' started by PsyberEMT, Apr 11, 2017.
Tags:
  1. PsyberEMT
    PsyberEMT Notebook Enthusiast
    Getting ready to order a P870KM from HIDEvolution and I'm wondering if anyone has ever added a WWAN card? As I recall there are now options for Sierra Wireless that are M.2 compliant. Would just need to find a place for the antennas to go (preferably behind the LCD for reception!). Would love to hear anyone whose done it on this chassis.
  2. KLF
    (I'm too lazy to check) does the chassis have sim card reader already? I've seen piggyback readers that could be added over the mpcie cards but not for m.2 yet.
    My laptop has m.2 Huawei LTE card.
  3. ssj92
    ssj92 Neutron Star
    No sim slot as far as I know
  4. Prostar Computer
    The models that do have it (I can't recall off hand whether the P870 does or does not), have it disabled somehow. I spoke with R & D about another model that had the slot, and was told it won't work (a customer tested and confirmed it around the same time).
    Why exactly, I'm not sure.
  5. PsyberEMT
    Helpful to know someone has tested before. Now that just makes my inner tinkerer want to make it work that much more just to prove a point lol.
  6. Prostar Computer
    If you figure something out, do follow up! It seems superfluous to have it available yet not working.
  7. Meaker@Sager
    It could well be a BIOS switch that's hidden.
  8. TomJGX
    TomJGX I HATE BGA!
    @Prema might have an idea?
    Sent from my LG-H850 using Tapatalk
  9. Prema
    Prema Your Freedom, Your Choice
    BIOS has support, but there is no native SIM card slot on P870xM series, so you would have to go another route to add it. Probably easier to get by with an external USB solution...
  10. Meaker@Sager
    Or pairing your phone which is what a lot have people have moved to which is why sim slots are less popular.
