Any way to manually turn on notebook fans?
Discussion in 'Windows OS and Software' started by Lakjin, Aug 13, 2008.
  1. Lakjin
    Lakjin Notebook Deity
    Okay, I know what SpeedFan. It doesnt seem to work for me.
    Is there any other way to turn on my notebook fans to full?
    I just got my Zalman NC2000. Played a dota game with it on full. So far, its epic failz, only lowered my temps by 2-3 all around. My theory tho is because my notebook fans didnt turn on to full like they usually do, since an external cooler was cooling it.
    So, back to the point of this post, is there any other way to turn on my notebook fans to full?
  2. Andy
    Andy Notebook Prophet
    The Fan Info is normally hard-coded into the BIOS and the ACPI and similar can access it. The fan comes on at about 50% when a certain temp of about ~45*C is exceeded and on 100% when temps exceed ~65*C.
    I have not heard of any software which can control fans through the SM Bus info. So, if you are experiencing high temps, try undervolting or check out the task manager, for what is the cause of the CPU usage.
  3. Lakjin
    Well its not nesseccary that I have a problem with what my temps are. I just wanted to test out how effective the zalman NC2000 is for my notebook, thats why i was wondering if there was a way to turn it on to full.
  4. Andy
    Turn on what to full, the external cooler or the notebook's heat-sink fan..??
  5. sheriffadam
    sheriffadam Notebook Geek
    NoteBook Hardware Control???
  6. Andy
    ^ Worth a try, depends if the ACPI Control System is configured for that system.
  7. duksandfish
    duksandfish Notebook Consultant
    You could Try Ik8fanGUI, though it is designed for dells....
  8. X2P
    X2P I♥COOLING | NBR Super Mod
    Wont work for anything but specific dells PERIOD!
  9. Lakjin
    And you dont know what effect it might have on your computer.
  10. Andy
    I've heard that it somehow/somewhat works in Acer Aspire 5315.
