Any way to make laptop cooler fan spin faster?
Discussion in 'Accessories' started by HellDemon, Jun 26, 2009.
  1. HellDemon
    HellDemon Notebook Consultant
    I just bought an Enermax Aeolus; it's not bad, but imo it spins wayyyy too slowly; I want it to go faster.
    Is there any way for that to happen?
  2. Soviet Sunrise
    Soviet Sunrise Notebook Prophet
    USB can only supply so much power to the fan.
  3. HellDemon
    Hmm so would I have to connect the USB to a USB-to-outlet plug? Or would i need to find an even better way to supply power to it? Cuz that's all I can think of =/
  4. paper_wastage
    paper_wastage Beat this 7x7x7 Cube
    USB standard says 5V @ 500mA along EACH PORT... which means if you have multiple devices connected using an self-powered USB hub, it's not enough
    some devices like the USB cooler might try to draw more power than the USB standard...
    you can get a USB hub with a power adapter... like this one, though the review for that one sucked
    or you could go macgyver and wire up your own power supply, if you know about electronics
    (hint... some USB HUB + Power adapter have a power adapter of 5V @ 2A... this means a total of 2.5A.... if the HUB has 7 ports and EACH port requires 500mA, you need 500mA*7 = 3.5A.... not enough....
    though usually you won't run into this problem... unless you run 7 external 2.5" HDDs)
  5. qhn
    qhn Notebook User
    More spins, more noise - constant and well placed fan position is best to cool down notebook environment.
    cheers ...
  6. Soviet Sunrise
  7. mujtaba
    mujtaba ZzzZzz Super Moderator
    You might want to take a look at some Coolermaster fans.
    And what has made you to want a cooling pad in the first place ? If your laptop has gone too hot, it might be time to clean up the laptop.
  8. HellDemon
    Lol its' a Studio XPS 13; that thing gets hot; the laptop cooler helps + undervolting, but undervolting does most of the cooling; but yeah, I just want this thing to be as cool as possible
    Fast fan rotation isnt exactly my main focus, moreso that I just want the fan that I have to spin faster
  9. whizzo
    whizzo Notebook Prophet
    sense you make not.
  10. Soviet Sunrise
