Any way to check power-on time for a machine?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by vinuneuro, Nov 4, 2013.
  1. vinuneuro
    vinuneuro Notebook Virtuoso
    I'm looking at a notebook that is advertised as brand new, open box, never used. The hard drive keeps track of hours in use. Is there any other way to verify it?
  2. Qing Dao
    Qing Dao Notebook Deity
    If it looks brand new and works like it is brand new, what more do you want?
  3. vinuneuro
    If I'm paying a premium for a new machine, I want it to actually be brand new.
  4. mattcheau
    mattcheau Notebook Deity
    sounds like a best buy open box deal or something, no? there's no real way to ascertain total uptime, but it's probably at least a few hours between QA/setup and whoever returned it. i wouldn't pay a premium for anything open box anyway since that's sort of counterintuitive.
    Sent from my Windows 8 device using Board Express Pro
  5. maverick1989
    maverick1989 Notebook Deity
    All the laptops I've had have done a "setting up for first time use" test with a screen stating the same. I don't know if that happens with all laptops. If it does, that would be a way to check if it has indeed never been used.
  6. baii
    baii Sone
    Closest you can get is look at harddrive power on hour.
  7. ajkula66
    ajkula66 Courage and Consequence
    The only laptops that display power-on hours are Panasonics and I'm pretty sure you're not after one of them...
  8. baii
    baii Sone
    huh I remember there was a thread on panny sub forum where a bug show power on hour of million years or something like that.
  9. Dufus
    Dufus .
  10. maverick1989
    That displays "power on hours". I think that means hours since the computer was turned on, not since it was turned on for the very first time (which would require hardware that kept count of time since first power on even when the computer shut down).
