Any issues using Sager notebooks overseas?
Discussion in 'Sager and Clevo' started by wpsaladin2, Oct 6, 2017.
  1. wpsaladin2
    wpsaladin2 Newbie
    Specifically concerned about power adapters. The brick that came with my machine appears to be the typical AC/DC adapter, and can handle the usual 100-240V, 50-60Hz range. In the past, I've just needed plug adapters for the wall and that's it. Are there are any situations one might run into where this wouldn't be enough, and you'd need some additional protection? Surge protector maybe?
    I plan on traveling through Asia, as well as Australia/NZ and possibly Europe. Thinking I should be good but I'd rather ask now than run into problems later. Thanks!
  2. KY_BULLET
    KY_BULLET Notebook Evangelist
    I've had mine in China a few times and had no trouble.
  3. Meaker@Sager
    The power consumption of even our most hungry machines is less than that of a decent powered desktop. So as long as the grid is good enough to run one of those then a notebook should be fine.
    Vasudev likes this.
  4. gunemalli
    gunemalli Notebook Guru
    I'm using one in Sri Lanka, 230V 50Hz, 25-35c ambient and high humidity.
    No issues so far.
  5. Husar
    Husar Notebook Consultant
    Hi wpsaladin2,
    I live in Australia and the adapter has been working fine since 2012. I traveled through Europe for 3 months and only used a plug converter during my stay.
    You can get some plug converters with surge protectors built in, either at Mediamarket in Europe or in Officeworks in Australia.
  6. Meaker@Sager
    I'd be more concerned you have a decent bag :)
    BioHazard17 and gunemalli like this.
  7. gunemalli
    True. I've a horrible old bag which gives me a back ache when traveling for long periods of time.
    Sent from my SM-G930F using Tapatalk
  8. Meaker@Sager
    Yeah you and your machine both deserve a decent bag ;)
    gunemalli likes this.
  9. gunemalli
    True, sourcing one is the hardest at the moment. Have to import one probably, that has the necessary padding and space because I'm using a sleeve for protection when transporting.
