"antivirus xp 2008 virus" need help
Discussion in 'Security and Anti-Virus Software' started by chesieofdarock, Aug 8, 2008.
  1. chesieofdarock
    chesieofdarock Notebook Deity
    Oops i forgot about subforums :eek: my bad thx arkit3kt
  2. taruian
    taruian Notebook Consultant
    hi thats a malware which installs itself.
    i have found how to remove that.
    it will be installed in windows folder, programfiles n startmenu too.
    first find the path where its installed itself, you can find it by right clicking on that xp antivirus 2008, takin properties of it n click in find target. then dont delete, if you delete it will keep replicating n installin itself gain n gain.
    so follow the steps below
    first download Uniblue's Spyeraser latest version n update the definition. then scan your system, you need the key to remove the spywares detected. pvt me if u need key.
    it will take around 30 minutes to scan your pc n list all the spywares, n it will deletes all those spywares, n you must let it run in background, so it will keep monitoring your pc for all suspicious activity.
    once it removes the spyware your system have no problem gain, :)
    the best thing of spyeraser is it keeps monitoring system32 folder there you will see many spyware/malware installing itself by name like vtfgdp.dll n so on.
    it will remove those files n keeps system32 folder safe, helps to avoid reinstallin pain.
    also check your startup programs n uncheck those whic are suspious, once you cleaned the those malware with spyeraser, now boot in safe mode n access your system32 folder n check for unknown dll files,
    the dll files which are marked as unknow by windows are the spywares n you delete those manually, if theres left any.
    also using regedit, go in to hklm/softwares/microsoft/ windows/ curentversion/run
    there in delete the files one which are unknown like some dll files vtypci.dll
    now your pc will be back in normal mode.
    i had much problem, but try using SPYERASER, its the best.
    i have tried almost all spyware program, but spyeraser is best.
    try n reply back
    have a nice day
    bye
  3. Hiker
    Hiker Notebook Deity
  4. taruian
  5. Hiker
    There's not much of a review there except for the software publishers description but I'll tale your word for it. If I didn't have 3 spyware programs installed (I uninstalled Spybot S&D 1.6 because it wouldn't start) I'd try it out.
  6. taruian
    hi hiker
    use the latest version of uniblue's Spyeraser 2.0.1.1531, update the definition, then register it.
    dont use many spyware program at once, use one spyware program besides ur antivirus program.
    the spyeraser is a microsoft gold certified.
    ty, leave a feedback after workin on it.
  7. hydra
    hydra Breaks Laptops
    I have seen this twice when surfing the Web. Both times I used Task Manager to quit MSE as i had bad feelings what would happen if I clicked ANYWHERE on that box...
  8. Baserk
    Baserk Notebook user
    You are right about the bad vibe you got...
    Check this thread for what you've 'missed'... ;).
    Cheers.
  9. hydra
    Thx, I had goggled "antivirus xp 2008" yesterday. It seems that quite a few people did try to close the box. It appears that Malwarebytes was able to remove it and there were a few manual search and delete methods posted.
