"antivirus xp 2008 virus" need help
Discussion in 'Security and Anti-Virus Software' started by chesieofdarock, Aug 8, 2008.
  1. chesieofdarock
    chesieofdarock Notebook Deity
    so my brother got this virus "antivirus xp 2008" that installs a fake antivirus which removes needed files and installs stuff to send your information to bad people :p anyways, anyone have any experience removing it? I found this guide but I wanted more info on the virus. what exactly does it do? Thx!
    http://www.bleepingcomputer.com/malware-removal/remove-antivirus-xp-2008
    (his computer is running xp)
  2. bmwrob
    bmwrob Notebook Virtuoso
    bleeping computer is a reputable site; following those instructions will probably work well.
    Don't know exactly what the virus does, and hope never to find out for sure. Good luck with the removal.
  3. SpacemanSpiff
    SpacemanSpiff Everything in Moderation
  4. powerpack
    powerpack Notebook Prophet
    Hi all! rob and spiff. I think OP should follow the links. But want to use the stage to say. There are people who know much about computers and don't use anti virus. If one is careful of the sites they visit, what they download and most important! Don't run executables! Even anti virus can't help. These email viruses are spread by user action not some dark mysterious voodoo. Sorry to OP but wanted to share. Hope all goes well.
  5. Hiker
    Hiker Notebook Deity
    I was just reading a post about Antivirus 2009 over at Wilders. It took Malwarebytes, SuperAntispyware and Avast to get rid of all traces. All free and worth installing.
  6. Micaiah
    Micaiah Notebook Deity
    My little brother's PC just got this Anivirus XP 2008 spyware a few days ago, and I can confirm that Malwarebytes will remove it.
  7. Hiker
  8. chesieofdarock
    mmk it worked to remove it, but he still can't uninstall programs on his computer for some reason. I'm going to do some reasearch and may just resort to a system factory restore
  9. Arki
    Arki Super Moderator
    chesieofdarock,
    I've moved your thread to the Security and Anti-Virus Software section. You should receive better help there.
    Good luck.
  10. Hiker
    That's cool but not any one anti malware program catches everything.
