Another D.I.Y Laptop Cooler Project [W.I.P]
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by hacktrix2006, Jul 28, 2021.
  1. hacktrix2006
    Thanks, I chose Stainless Steel due to it being heavy which means i won't be chasing my laptop round, but also because i like to buff stuff to a mirror finish too. Yes converting to Aluminum would be good to make a heatsink from the stand however using steel also has the advantage of being structurally more stable.
    As for the Molex Vs USB, after seeking advise from @Mr. Fox i agree with what he said and the risk of frying a USB on this expensive laptop is not worth it. Not only that going to Molex makes life for me easier it means i don't need to solder anything.
    I can't wait to complete the whole thing, yes its complicated however it will be built to last with maintance and replacements being easy to do.
  2. Tech Junky
    Tech Junky Notebook Deity
    USB w/ external power supply was the intent not using the ports on the laptop.
    Structurally AL can be as firm as you want with thickness / braces applied to it. If they can make vehicles out of it I'm sure a laptop stand shouldn't be an issue other than the welding method changes needed.
    Just offering suggestions.
  3. hacktrix2006
    Thanks for your suggestion, I am grateful.
    Sent from my SNE-LX1 using Tapatalk
    Mr. Fox likes this.
  4. hacktrix2006
    Just an update, the new one hasn't been made yet, will have to chase my friend about it as I will be purchasing the stuff very soon.
  5. Jovial_Jack
    Jovial_Jack Newbie
    Fun project! I've done a half dozen home-baked laptop cooling trays, but I was lazy about building the base portion myself. Here's what I whipped together for the many I've done.
    3V-12V variable power adapters https://www.aliexpress.com/item/4000059020591.html
    DC to molex adapters https://www.ebay.com/itm/253640728449
    Fan hubs https://www.aliexpress.com/item/32858309490.html
    For mine, I just mount 120MM fans to the bottom of these fan trays with anti-vibration silicone screws
    https://www.aliexpress.com/item/33045976178.html
    https://www.aliexpress.com/item/1005001470183277.html
    I look forward to seeing how your project turns out.
    Mr. Fox, Papusan and hacktrix2006 like this.
  6. hacktrix2006
    I have all the items i need to buy sorted, just having to sort out getting the new stand made right now. However thanks for the suggestions.
    Papusan likes this.
