Another brand subwoofer in a CLEVO
Discussion in 'Sager and Clevo' started by MahmoudDewy, Jul 4, 2018.
  1. Lightning_-
    Lightning_- Notebook Geek
    @ssj92 MSI GT72 Sub dims: 2-1/8"W 15/16"H 2-13/16" L . Seller just told me. I want to put it in my p770DM, L&W is fine for HDD bay, but yeah the height is too much as you said @Danishblunt . Above the HDD bay is my touchpad. Are there any slimmer subwoofer options anyone could suggest? The available height I can get is around 5/8".
  2. Danishblunt
    Danishblunt Guest
    You can look into the L702x sub or older subs from the MSI GT 70 / GT 60 series, they are still good and will barely fit. Your best shot is going for a L702x sub and mod it with a custom box. The GT 70/60 are still rather high, so it will be quite some fiddlework while the L702x sub not as high, hence rather easy to pull off.
  3. Lightning_-
    Thanks for the suggestions. I have a 3d printer so I could make a custom box. Do you know if I could mod the gt-72 sub with a shorter custom box? I just don't know if the gt-72 sub has enough empty space inside for this.
  4. poprostujakub
    poprostujakub Notebook Consultant
    MahmoudDewy and Danishblunt like this.
  5. Support.3@XOTIC PC
    Support.3@XOTIC PC Company Representative
    Awesome, thanks for posting!
  6. Danishblunt
    Danishblunt Guest
    This is a very cool mod, even tho the sub seems rather weak, or whatever recorded the audio was bad.
    Could you try this with something like a GT 72 sub? :)
  7. Danishblunt
    Danishblunt Guest
    I think it might be 2 high, I might be wrong tho since I didnt open the box of a GT 72 sub yet, but I know that a GT 70 sub is height wise a bit complicated to fit into a clevo system. So maybe you can ask mafia abought the height of the actual sub without the box.
    Lightning_- likes this.
  8. Lightning_-
    @DaMafiaGamer would you know the height of the actual gt72 sub without the box? It's a bit too high for my clevo p770dm hdd bay, so I'm wonderining if I could redesign a shorter custom box for the gt72 sub itself to make it fit. The height available in my hdd bay is exactly 18.71mm or just under 3/4 in.
  9. ssj92
    ssj92 Neutron Star
    Yeah I'm going back home tomorrow for the weekend. I'll get to measure my HDD caddy and see if it'll fit. If it will I'll try it out.
    I just hope the laptop can drive the new sub. Increasing the Bass from 40% (default) to 100% in the sound blaster doesn't help much. So I don't know if it'll help switching to the other sub.
  10. Danishblunt
    Danishblunt Guest
    @MahmoudDewy
    @ssj92
    @Lightning_-
    I did not change the hardware on that clevo notebook. I made this for you showcasing that even if you swap out the sub you very likely won't notice a big difference. I swapped out the sub on different clevo models and all did improve a little bit, but still were not noticable enough to make a difference worth the upgrade, however after making my own sound driver mod now the difference is not only huge stock but also with a bigger sub.
    Use headphones otherwise you won't hear a difference if your speakers are poop.
