AMD's Ryzen CPUs (Ryzen/TR/Epyc) & Vega/Polaris/Navi GPUs
  1. TANWare
    No way would I even attempt this.
  2. Deks
    Deks Notebook Prophet
    And not really worth it considering he got only 1 deg C reduction.
    We already knew that AMD was using high quality solder for their lids... and that temperature reduction from de-liding was minimal to non-existent.
    hmscott, ajc9988 and jclausius like this.
  3. Papusan
    For science but not for sale.
    hmscott, ajc9988, jc_denton and 2 others like this.
  4. jc_denton
    jc_denton V̖̟en̰g̻̼̰̩͙ea̲n̪c̭e̼ ͍̘̤͓̟̤Is̙͔ ̤Mi̻̭̣͎͍ͅn̰ḙ
    I bet if you had some pressure film on the chiplets, you'd see that contact pressure is not ideal. With that many different surfaces, even the tinniest z-height offset will pretty have serious consequences. So only thing worth lapping would be the IHS itself.
    hmscott and ajc9988 like this.
  5. Deks
    Possibly, but realistically, what kind of reduction in temps could we expect?
    Even 5 deg C reduction is not worth all the delid wok which could also destroy the cpu.
    10 deg C? Possibly, but given existing zen 2 stock temps, not worth it.
    hmscott likes this.
  6. jc_denton
    On the 9900K you get significant temperature improvements when lapping the die, as it's 2x thickness of an 8700K.
    Easily dropping 15-25c when paired with LM and copper ihs.
    Contact pressure is key. Liquid metal will better than STIM, if proper contact is present. And judging from Der8auer's video, you'd need to lap the chiplets to achieve this. But the layout makes this a challenge, as capacitors surround the whole top side of the chip.
    But it's not worth the risk. Better solution would be having a lapped IHS with a waterblock that has a large microfin area covering all the chiplets.
    hmscott likes this.
  7. Cass-Olé
    Cass-Olé Notebook Evangelist
    While Newegg's $900 price feels awful, there are three MC's in my area; two stores are sold out which suggests they'd had some prior & may re-stock soon. I could buy one today, ~30minute drive
    3960x also in the wild @ MSRP
    jc_denton likes this.
  8. jc_denton
    Pretty sure these are selling like hotcakes right now
    hmscott likes this.
  9. Deks
    That may be the case with Intel CPU's, but we have had previous de-lidding attempts at AMD cpu's that noted the temperature reductions were minimal and therefore not worth the risk, because AMD was already using a high quality solder... Intel on the other hand doesn't.
    ajc9988 and hmscott like this.
  10. ajc9988
    It's not necessarily that they are using a lower quality solder. There are tolerances involved.
    But, you are correct. Same person, Roman, delidded the first gen single die Ryzen and only for 1C difference, although I cannot remember if he did direct die on that or LM between the die and IHS.
    Either way, it shows AMD is doing an excellent job regarding soldering.
    Also, as a side note, AMD is using Intel's patent for soldering chips.
