AMD's Ryzen CPUs (Ryzen/TR/Epyc) & Vega/Polaris/Navi GPUs
  1. rlk
    rlk Notebook Evangelist
    Depends upon what your integration tests are doing -- if they are creating lots of VMs themselves, you could blow through 64GB in a hurry.
    Assuming AMD does stick with AM4 for one more generation, going beyond 64/128GB may be difficult.
    hmscott and TANWare like this.
  2. TANWare
    As far as AM4, if at only 4 dims with a max of 32gb a stick of DDR4, 128 GB is the limit.
  3. rlk
    That depends upon the availability of 64GB DIMMs. It may be that a 6xx chipset will be needed to use those DIMMs, but certainly not everyone needs that.
  4. Deks
    Deks Notebook Prophet
    I have to question on the number of people creating massive amounts of VM's with huge RAM requirements.
    Even so, blowing through 64GB quickly might be doable indeed, but through 128GB?
    Not what I would consider practical for most home users.
    The amount of work involved to blow through 64GB alone will be really big... nevermind 128GB.
    I still maintain that 128GB limit should be large enough for the foreseeable timeframe even for massive RAM requirements when working with 16c/32 thread CPU... but if you may need even more RAM, wouldn't Threadrippers be a better choice for that?
    I mean, that's what they are for are they not?
    Most users who stick to AM4 platform probably won't need more than 64/128GB RAM even with large workloads (at least not for the time being).
    Most people are barely upgrading their systems to 64GB if they can afford it... I don't see too many systems or users with 128GB (even though some are probably out there), mainly because getting that kind of RAM amount can increase the overall costs of the platform by quite a lot.
    16GB to 32GB is kind of a 'standard' today for a gaming/productivity platform. 64GB would be considered 'optimal' for video editing as After Effects alone can chew through the RAM easily (as can 3d rendering)... but 128GB?
    Hm... useful yes, but right now, I'd say its a bit of an 'overkill'.
  5. rlk
    For most people, certainly. But think about, say, someone who's developing Kubernetes and wants a local multi-node cluster without having to use external cloud infrastructure. You may not need the amount of processing power a TR offers, but you're going to need a good amount of memory. It's doable on my 4-core i7-6820HQ with 64GB RAM (with 3 master nodes and 3 workers), but those have to be pretty small nodes with not a lot of RAM to spare, so I'm not going to be able to run many even quite small pods on them. 128GB would help a lot, and 256GB would be a cinch, but I don't need more than 12-16 Ryzen 3 cores, which are much faster than my old mobile Skylake ones.
    If something can "chew through [64GB] easily", it's not far from chewing through 128GB (a factor of 2 is pretty small potatoes).
    tilleroftheearth and TANWare like this.
  6. TANWare
    The thing here too, is AMD wants 16 core TR users to now consider AM4 as their new platform. There then are the platform limitations. You also have to remember we are talking in any of thses situations as specific and specialized use cases.
    An Edit;
    The TRX40 boards seem to support 8 DIMMs, as did the x399, but support 256GB total instead of just 128GB!
  7. Deks
    In that case, get Zen 2 16c/32th and go with 128GB. Chances are it will last you a while. Possibility exists you will be able to double that to 256GB with Zen 3, however, its not a guarantee as we don't know if its mobo that's limited or just down to CPU support (my bet is the mobo can support it, its the CPU that needs to be designed with higher RAM support).
    With TR you have that guarantee (and yes, even though the non-TR 16c/32th CPU has more than enough horse power for you, fact is, Zen 2 atm doesn't support more than 128GB, so you'd be stuck with that RAM, especially if Zen 3 doesn't increase RAM support).
    Might as well go with an entry level Zen 2 TR and 128GB RAM to get you 'started' and then upgrade to more RAM and possibly Zen 3 TR if/when the need arises.
    On a side note, its worth mentioning that AMD considers Zen 3 a 'brand new uArch'.
    I would imagine that kind of change would in fact bring with it changes to include higher RAM support, but as I said, there are no guarantees.
    hmscott likes this.
  8. hmscott
    Buildzoid does a massive AM4 18 motherboard review...
    Best Motherboards for AMD Ryzen: R5 3600, R9 3950X & B450, X570, X470
    Nov 29, 2019
    Gamers Nexus
    The best motherboards for AMD Ryzen CPUs in 2019, from B450 to X570, covered in one place. This updated version of our guide considers the R9 3950X & R5 3600.
    In this video, we're only looking at motherboards we know are acceptable for AMD #Ryzen CPUs, eliminating the bottom-of-the-barrel boards to establish a baseline level of quality.
    If you're trying to figure out what motherboard to use for your new AMD Ryzen system, particularly with the Ryzen 3000 series (e.g. R5 3600 or R9 3950X), this motherboard guide rounds-up what's worth considering and talks about suitable VRMs for the newer CPUs.
    Note that not every board on this list should be paired with the 3950X, as it has stricter VRM requirements than the lower-end CPUs due to the increased core count.
    Also note that, if you're trying to compare the differences between X470 vs. X570 boards or X570 and B450 boards, they'll mostly boil-down to PCIe Gen4. We talk about that in this content, too.
    Our goal is to help provide a list of the best motherboards for AMD's Ryzen CPUs in 2019, particularly the newer R9 3950X and R5 3600 CPUs. We hope that this will be useful for PC builds before end of year and for sales (like #CyberMonday deals).
    Find Buildzoid here: https://www.youtube.com/channel/UCrwO...
    Beware there's likely codes for referrals in these MB links, be sure and clear them as needed to avoid giving help to GN, if you don't want to. Sorry too tired to strip the links right now...
    **ULTRA HIGH-END AM4 MOTHERBOARDS**
    00:57 - Best VRM/Heatsink Combination: Gigabyte X570 Aorus Xtreme (Amazon) - https://geni.us/jfQLm
    02:38 - Best Ultra High-End with Thunderbolt 3: ASRock X570 Creator (Amazon) - https://geni.us/kA90gn9
    **WELL-ROUNDED HIGH-END BOARDS**
    03:52 - Gigabyte X570 Aorus Master (Amazon) - https://geni.us/gCnAio
    05:23 - ASUS X570 ROG Crosshair VIII Hero (Amazon) - https://geni.us/kyTutd
    07:16 - MSI X570 UNIFY (Amazon) - https://geni.us/thdh
    08:35 - ASRock X570 Taichi (Amazon) - https://geni.us/X9o3p5D
    **CHEAPEST 10GbE LAN**
    11:13 - ASRock X470 Taichi Ultimate (Amazon) - https://geni.us/dzJ4
    **BEST MINI ITX RYZEN BOARDS**
    13:09 - ROG Strix X570-I Gaming (Amazon) - https://geni.us/lqVFi
    13:59 - ASRock X570 Phantom Gaming ITX (Amazon) - https://geni.us/J1cKHm
    **BAREBONES / GO-TO AFFORDABLE X570 BOARDS**
    15:25 - Gigabyte X570 Aorus Elite (Amazon) - https://geni.us/BAuR
    16:34 - ASUS TUF Gaming X570-Plus (Amazon) - https://geni.us/mMRqN
    18:12 - ASUS Prime X570-P (Amazon) - https://geni.us/sjNKF
    **BEST B450 MOTHERBOARDS**
    20:25 - MSI B450I Gaming Plus (Amazon) - https://geni.us/pj5sTpd
    22:03 - MSI B450 Tomahawk Max (Amazon) - https://geni.us/Sv3CK
    23:00 - MSI B450 Mortar Max (Amazon) - https://geni.us/4EKc4
    **CHEAP B450 BOARDS THAT AREN'T TOTALLY GARBAGE**
    24:43 - Gigabyte B450 Aorus Elite (Amazon) - https://geni.us/uKGBdk
    26:32 - MSI B450 Gaming Plus Max (Amazon) - https://geni.us/zDbIcyq
    **WELL, IT COULD BE WORSE DIRT CHEAP BOARD**
    27:45 - Gigabyte B450 Aorus M (Amazon) - https://geni.us/KmD0sPh
  9. TANWare
    hmscott likes this.
  10. TANWare
    Now, if we could only get one;
    hmscott likes this.
