AMD's Ryzen CPU's (Ryzen/TR/Epyc) & Vega/Polaris GPU's
  1. James D
    James D Notebook Prophet
    People who search how much future proof products are before they buy actually don't mind sacrificing small amount (or any amount as long as it is still digestible) of performance in 3+ years because they don't plan to buy new PC in same 3+ years accordingly. You don't look at future-proofing if you don't care about money, do you?
    Papusan and ajc9988 like this.
  2. ajc9988
    Except, Sandy and Ivy bridge still have a huge part of the market. How many years is that? Not everyone upgrades on the cadence, only enthusiasts. With the power in the modern chips on both sides, and Ryzen and Intel's 8700K being the main increase making upgrading worth it if you had a sandy bridge CPU, I'd argue that it is equally future proof, except you would have more upgrade options down the road on the same platform on the AMD side.
  3. Vasudev
    Still use my Ivybridge pentium laptop and have an old Radeon 5750.
    Robbo99999, ajc9988 and hmscott like this.
  4. hmscott
    Thoughtless newbies throwing money out the window aren't really considering much more than straight line performance, FPS, when making their buying decision.
    Cost and price limit's hone the buying choices and help force the buyer to consider other criteria than straight-line performance when making the purchase decision.
    When you have $M's to spend on computer hardware, you might think cost isn't an object of consideration, but considering price / performance plays a vital role in focusing the spend on value.
    The considerations that come from the price / cost of choice help make smarter and better solution choices than only using straight-line performance at any cost.
    In fact you'd quickly lose your purchasing ability making decisions based only on the numbers from straight-line performance metrics.
    Consumer purchases are the same, you need to be price sensitive and also look at cost, don't overspend on the wrong metrics, missing out on the wider picture.
    If you can get more cores for the same cost providing better multitasking performance along with future multi-core software performance improvements, and only give up a non-noticeable percentage of straight-line performance, then an AMD CPU with more cores is a better buying choice than a higher clocking Intel CPU.
    If you are going to get fooled chasing metrics meaningless in everyday use, you'll quickly go broke on upgrades constantly trying to chase the numbers.
    In real life use, those numbers get exceeded by new products on a regular basis, that top performance metric machine is going to quickly lose it's value to you, and you'll never be happy with what you have.
    Figuring out how to be happy with a little less performance for less cost is a good way to start being happy over the long term with your purchase. :)
    ajc9988 likes this.
  5. TheReciever
    TheReciever D! For Dragon!
    Yeah I used to be one of those guys chasing the benchmarks.
    I should've kept the 1055T system I had back in the day instead of trying to get the first gen i7's. That 1055T was the easiest 4Ghz overclock I ever had. I sold it to make a point to my brother though. Told him he could keep the PC if he gets a job even if its just some part time gig. 1055T and 4870x2 was a good combo back then. He refused to get a job so I sold it.
    Its why I am ok with my Ranger, I already knew Haswell was good enough for my needs and can upgrade the GPU through MXM.
    Next system will likely be be the Acer Helios 500 provided the firmware is sound. If the 7950 can last as long as it has, I think Vega 56 and 2700 will be fine for a while yet. Here's hopin'.
    James D and hmscott like this.
  6. hmscott
    Vasudev likes this.
  7. Deks
    Deks Notebook Prophet
    Some news regarding AMD Vega on 7nm:
    http://www.itp.net/617514-amd-demos-7nm-gpu
    "AMD claims the new 7nm process is twice as dense as its 14nm process, and the 7nm Vega die appears to be roughly 40% smaller than its predecessor. The new process also affords a 2x increase in power efficiency and AMD also claims it provides a 1.35x increase in performance."
    Note that they don't seem to mention that the process will result in 2x increase in efficiency OR provide 1.35x increase in performance... but rather they continue to describe both 2x increase in efficiency and 35% increase in performance as something that goes hand in hand on 7nm TSMC.
    So, if Vega gains 35% increase in performance and is double the efficiency at the same time... I wonder how this new process might affect the yields (and subsequently voltages) on 7nm vega (and Navi) and if it might result in Vega and Navi being clocked much higher and gain more performance given that Vega on 14nm suffered from high voltage problems and mauf. process designed for low clocks which forced AMD to use low clocks.
    Thinking about Pascal, it was clocked about 30% higher than Vega was, mainly because the process was suitable for high clocks and PAscal had auto voltage tuning, and less compute units... (though this produced roughly similar or lower performance to lower clocked Vega 56 and 64 - except of course the 1080ti)
    Turing architecture from what I understand is more AI oriented... so, no real benefits for games.
    And Nvidia also said it won't be releasing a new GPU for a long time (though things are open to change)... at best, Nvidia could refresh Pascal on 7nm.
    It would be an interesting 'treat' if Vega suddenly on 7nm ends up equating or beating 7nm refreshed Pascal and with Navi just around the corner - but I guess only time will tell.
    Right now we're getting figures from the manuf.process improvements... no word on whether AMD improved/optimized Vega's internals, etc.
    EDIT: Still bearing in mind that the 2x increase in efficiency and 35% performance increase could be an error on the article writer (or algorithm) and could easily still end up being one OR the other.
    It's just that until now, articles seem to say that both will occur (which of course is not consistent with history - but then again, that 35% increase in performance could be due to the node eliminating the bottlenecks of 14nm LPP).
    hmscott and Vasudev like this.
  8. ajc9988
    I explained this **** to you already. How you achieve both on a curve is due to other factors at work, such as faster memory and other refinements.
    Meanwhile, what I didn't explain was that AMD confirmed they are doing multi-die, just not for consumers because ISVs will not program for NUMA on GPUs for games. Software on the server side doesn't care and can use as many cards as you drop in. Nvidia's multi-die paper shows them also doing NUMA for multi-die GPUs. That means that until software vendors designing games add support, you have to go monolithic on consumer graphics. Also, 35% improvement on Vega puts it at or above 1080 Ti levels. Navi is rumored to be around 1080 to Ti levels also, but with less power to be used for embedded solutions.
    Vasudev and hmscott like this.
  9. ajc9988
    This is the curve. You cannot exit the curve. That means that if you exceed the values on the curve, it comes from other changes, such as memory, architecture tweaks, etc. I also showed that GF is using the same pitch as TSMC, and by some measures, GF is slightly denser on 7nm, but density is hard to calc between fabs.
    jaybee83, Vasudev and hmscott like this.
  10. ajc9988
    On other news, in the past week, Asrock has released BIOS updates for the B350, the X470, the X370, and the Z370. So, the X399 should be coming soon.
