All laptops with a MUX switch
Discussion in 'Hardware Components and Aftermarket Upgrades' started by B0B, Feb 6, 2018.
  1. Georgel
    Georgel Notebook Virtuoso
    No, no, that is true, but if you actually have iGPU via Optimus the data is routed through the iGPU and motherboard even when processed in the dGPU, you always have that delay. It only works well if the switch is exclusive. I suggest they do implement this, might help some gamers at some point
    ole!!! likes this.
  2. Starlight5
    Starlight5 So what if I'm crazy? The best people are.
    Even most smartphones have FP readers nowadays. Removing it from a high-end laptop doesn't sound like a good idea to me.
  3. ole!!!
    ole!!! Notebook Prophet
    do u use it on laptop? if u do u'll see the value of it. i dont use fp reader at all i think its a dumb security measure that can easily be bypassed, just more of a gimmick than anything really.
  4. Starlight5
    @ole!!! of course I do. But personal experience is not the point here, is it? The point is, excluding feature that is now frequently included even in lower-end machines, let alone any workstation, definitely won't improve sales.
  5. Mobius 1
    Mobius 1 nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ⎬⎛⎝⎠⎞⎨
    Why are people arguing that MUX chips shouldn't be in a laptop.
    Making a gaming laptop able to last a respectable amount of time unplugged is a plus to me, and it'll entice more people to buy the said laptop due to its multipurpose nature.
    When done correctly (iGPU, dGPU and mshybrid/optimus), a MUXed laptop would be far more useful compared to an unMUXed one.
    I was able to take my P71 as a DTR and travel device during holiday due to the MUX, sadly couldn't say the same for the KM1.
    On topic.
    ThinkPad P70/P71 (MXM) has MUX to switch between Optimus and dGPU only (iGPU turned off completely).
    Not sure how the case is with the P50/P51 and other models that have a discrete graphics built in.
  6. chezzzz
    chezzzz Notebook Geek
    just curious, now that it seems that the Clevo P650 series has been retired (not being manufactured anymore by Clevo, and not being stocked anymore by many boutique sellers of higher-end laptops), is there a newer replacement model made by Clevo that still has / incorporates a MUX Switch ?
    also, are there any other newer model higher-end laptops in general (as of this writing and since 2018 Computex & E3) that will incorporate a MUX Switch capability ? any info & input appreciated, thanks all !
  7. yrekabakery
    yrekabakery Notebook Deity
    Clevo PA7xEP6-G/ES-G, although it's not technically a replacement for the P6 series.
    Vasudev and chezzzz like this.
  8. chezzzz
    thanks for the info, that seems like a very nice unit. however, that is a 17"inch Clevo model, and the P650 series is/was a 15"inch Clevo model. appreciate the info nonetheless, thanks again.
  9. rinneh
    rinneh Notebook Prophet
    I have the feelin gthis is very outdated and not the case anymore to be honest. The current Alienwares have a mux switch and can run in discrete only and I could not measure any extra input lag in Optimus mode (tested it with a slow-mo cam.
    Also 8ms input lag is not the same is not ditching half of the CPU power......
  10. rinneh
    Optimus has become so much better in recent years. I never had to manually assign a GPU to a game for example. The past 4 years using Optimus laptops. The only real downsid eof optimus is the lack of Gsync support imo. In all other cases it just works and it offers me a 8 hour of battery time when on the road for mild productivity and just watching movies in an airplane.
