Alienwarefx not working
Discussion in 'Alienware M15x' started by Z V I E R A T, Dec 31, 2016.
  1. Z V I E R A T
    Z V I E R A T Newbie
    Every time I open alienwarefx it says "The device you have selected is included in the current theme but AlienFX cannot detect this device on your system. Do you want to remove this device from the current theme?" And if I press no, whenever I change the color nothing happens. And if I press yes and try to change the color it says"
    System.NullReferenceException: Object reference not set to an instance of an object.
    at AlienLabs.AlienFX.Editor.Controls.ActionColorPickerControl.processSelectedColorChanged(Color primaryColor, Color secondaryColor)
    at AlienLabs.AlienFX.Editor.Controls.ActionColorPickerControl.selectedColorChanged(Color primaryColor, Color secondaryColor)
    at AlienLabs.AlienFX.Tools.Controls.DynamicColorWheel.onSelectedColorChanged(Color primaryColor, Color secondaryColor)
    at AlienLabs.AlienFX.Tools.Controls.DynamicColorWheel.selectColotItem(PathRadioButton element, Boolean rotateIndicator)
    at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
    at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
    at System.Windows.Controls.RadioButton.OnChecked(RoutedEventArgs e)
    at System.Windows.Controls.Primitives.ToggleButton.OnIsCheckedChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
    at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
    at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
    at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
    at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
    at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
    at System.Windows.DependencyObject.SetCurrentValueInternal(DependencyProperty dp, Object value)
    at System.Windows.Controls.Primitives.ToggleButton.OnClick()
    at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
    at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
    at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
    at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
    at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
    at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
    at System.Windows.Input.InputManager.ProcessStagingArea()
    at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
    at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
    at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
    at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
    at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
    at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)"
    Please help,
    Z V I E R A t
  2. kosti
    kosti Notebook Virtuoso
  3. Z V I E R A T
  4. MZWiZard
    MZWiZard Notebook Consultant
  5. maxslo
    maxslo undefined
    First thing first, are the lights working? If so, install .net framework 4.5.2 try the alien fx once again.
    If the lights are not working from the moment laptop turns on you will however need the alienfx chip to be reflashed. I can do that for you if you wish or write you up on how to do it, you will need to get special tools to do it tho.
  6. kosti
    If you install the Command Center from the Dell disc after previously having installed a newer version of Command Center from Dell's site on that same motherboard, it may have corrupted your AlienFX chip's firmware.
    If this applies to you, you can:
    - Send your laptop to someone with the tools to reprogram the AlienFX chip (like Maxslo)
    - Buy the chip programmer and download the software to do this yourself
    http://en.community.dell.com/owners-club/alienware/f/3746/t/19442434#20076741
    - Get a new motherboard
    - Leave it as it is.
  7. Mobius 1
    man not this again
