Alienware m18xr2 gtx980m help
Discussion in 'Alienware 18 and M18x' started by NODicce, Jan 31, 2018.
  1. NODicce
    NODicce Notebook Enthusiast
    Prema likes this.
  2. NODicce
    and @Raidriar the exact method i have done to test again is
    1.reboot to safe mode
    2.DDU clean and restart to safe mode
    3.install nvidia driver 387.98 custom/clean install.
    4.reboot
    5.bios => windows splash screen => black screen on login with sound
    6. reboot
    7. restart from begining with 390.77 drivers instead with same outcome
    8. revert back to Mr.fox modded 345.20 driver
    9. reboot and works fine.
    also is there a way to add attachements to this? i have pictures of bios, nvidia control center and nvidia driver in device manager.
  3. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Then I have no idea. It's very strange that all these people lately have been having 980M install issues, mine went in without a problem with both Clevo and Dell cards/vBIOS.
  4. NODicce
    @Raidriar are you using the a11 unlocked bios by swick ? Or standard bios? I'm not sure why mine is being this way, and why the old drivers work and not the new. Is there maybe a bios setup I missed or something. When I installed card at first I did this as far as I can remember
    1. Flash system bios to a11 unlocked by swick
    2 powered off installed card ect.
    3 powered on installed old modded driver.
    4 restart and it worked
    and at @Prema i came across this site and drivers by @j95
    https://www.techinferno.com/index.p...t-upgrades-driver-support-modded-inf/&page=66
    saying your vbios are required for drivers. is there a way i can get those for my 980m? ive tried your site and the TechInferno site but with no luck at finding them or which i would need, thanks in advance.
  5. Tulius
    Tulius Notebook Consultant
    Hey I think I can help you in this case:
    First install Mr.fox modded 345.20 driver then ask Prema about his modded 980M Clevo vBIOS 2.0 (nom gsync version), get it and flash both cards if SLI, this is needed if want to install newer Nvidia drivers, otherwise you get a black screen. Hope it helps.
    See my signature.
  6. NODicce
    Hey thanks for the input, I was somewhat leaning toward the vbios being the problem just from reading another old forum. Hopefully I can get my hands on them
    @Prema could I get the vbios off of you that I require for my aw m18xr2 gtx980m?
    If you point me in the right direction I've got no problem donating or anything like that, I did read you are hesitant on giving this out now due to some people.
  7. NODicce
    ok so ive just done pretty much everything i can think of to try and get updated drivers to work, ive tried multiple Drivers and ive DDu'ed everytime, ive tried the drivers thru windows support, tried messing around with bios setting in the a11 unlocked bios. Ive contacted nvidia support and they havent been able to help at all. im at my wits end here this is driving me nuts i cant figure out why the older driver is working flawlessly after install and nothing else works. @Prema the only thing i havent tried is your vbios. i know you and your team is probably way past this m18xr2 thing but if you have any info or something i may be missing it would be greatly appreciated
    is it possible that flashing to a different stock vbios might help? dell to clevo or visa versa?
  8. Tulius
    Without Prema's vBIOS you're missing a major piece of your upgrade task and I doubt any other default VBIOS will do the trick in this case.
  9. NODicce
    Alright, thanks @Tulius im really at a loss here this has been driving me up the wall for like a week and a half. i guess all i can do is hope @Prema answeres me at some point.
  10. NODicce
    I've tried a few other solutions with no real success, I'm curious is it possible it's failing because of my power supply? I'm running the original 230w power supply which is not working correctly anymore, it does power my laptop but I get a plugged in not charging and the adapter in bios is "unknown" is it possible that when I update drivers it's causing it to die because it is needing more power? I know in the plugged in not charging state it reduce's performance. Just a thought.
