Alienware M18x R2 with 980m - Throttling fix
Discussion in 'Alienware 18 and M18x' started by pickart, Feb 18, 2019.
  1. pickart
    pickart Newbie
    Hello everybody.
    I own an M18XR2
    I also suffer the problem of having to perform this operation to avoid delays:
    1) Power up (or reboot) and keep pressing F2 to enter BIOS
    2) From the Advanced menu and Video Configuration, select as primary the IGFX
    3) Save and exit and reboot and keep pressing F2 to enter BIOS
    4) From the video configuration select PEG
    5) Save and exit and boot to windows.
    With this the laptop works perfectly.
    Is there anything new about this? To avoid having to perform this procedure every time.
    Regards
    My system is:
    AWM18XR2 (MOD BIOS SWICH 11)
    CPU: Intel® Core™ i7-3940XM CPU @ 3.00GHz - 3.20GHz
    GPU: GeForce GTX 980Mx2 SLI – DRIVER 418.91 (13/02/2019)
    RAM: 32GB SAMSUNG
    SSD: RAID 0 (1TB) x2 SAMSUNG 850 EVO PRO 500GB + SAMSUNG 850 EVO 1TB
    OS: Windows 10 Pro 1809
  2. vulcan78
    vulcan78 Notebook Deity
    How did you get Windows 10 to work with the R2? Last I heard there was an issue with it bricking displays. Just curious, I have to reinstall Win 7 on my R2 once I acquire a boot drive, I have Win 10 on my desktop PC, and there's a few reasons to want to upgrade (once you turn off the spyware nonsense on 10), specifically, the ability to play Microsoft Store exclusive titles such as Forza Horizon 3 and 4, even though my single 980M will have it's work cut out for it at 1080p.
  3. pickart
    pickart Newbie
  4. pickart
    pickart Newbie
  5. M18x-oldie
    Iirc there was no issue installing and running that "bright and wonderfully perfect, masterpiece version of OS" on the r2.
    Had it also running on a r1 of a friend.
    The bricking was caused by the usage of either precision x or afterburner on this OS.
  6. imest
    imest Notebook Consultant
    The bricking of displays was due to overclocking utility in Win10. EVGA Precision bricked my EDID and had to replace the LCD. Just use Ntune and do not load any other overclock utility, imo.
  7. vulcan78
    Nice! How do you overclock the 980M's?
    Even AB? I thought it was just PX, but it would make sense considering EVGA stole / copied MSI AB directly.
    Even AB?
    Thanks for the replies.
  8. imest
    I don't use After Burner but I think that one is okay to use.
