Alienware M18x R2 with 980m - Possible throttling fix
Discussion in 'Alienware 18 and M18x' started by jerryzago, May 7, 2016.
  1. vulcan78
    vulcan78 Notebook Deity
    Thanks for the corroboration, just read this after posting my last post above.
  2. vulcan78
    The potential throttling issue is the reason why I am interested in replacing 680M SLI with a single 980M as that should be good with 330W even OC'd.
  3. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    yes, they're undervolted so it's impossible for them to over-draw power
  4. vulcan78
    Hmmm, while not likely, do you think it could be your PSU is on it's way out?
  5. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    No. nVidia has crappy driver support for anything pre-Maxwell. Maxwell will go the same way soon now that Pascal is out and about.
    Mr. Fox likes this.
  6. @tomX
    @tomX Notebook Evangelist
    So after a while, all you guys are using this trick to be able to use recent Nvidia drivers or did you go back to old Nvidia drivers?
  7. vulcan78
    I'm using the latest driver in conjunction with this trick. It's only tedious if you end up with Display Driver Failures and have to restart as the trick needs to be reapplied every time.
  8. @tomX
    thanks for the feedback Vulcan. Those DDF happen often? what causes them?
    Other users of this trick?
  9. vulcan78
    No, they only happened because I tried running to much frequency on the core, i.e. +149 (1275Mhz) vs. the +136 that is currently very stable.
    Let me know if you need help getting the newer drivers to work, you will need to modify them with a .inf file as there are no official drivers for 980M in the M18x R2.
    Also, if you've yet to do so, I HIGHLY recommend Prema's vbios, I picked up 1k points GPU in Firestrike with identical clocks simply going from the default vbios to Prema's.
    You can expect about another 3-4C higher peak load temps though so have that aggressive Hwinfo64 fan algorithm ready! Also don't forget to elevate the back of the laptop.
  10. TBoneSan
    TBoneSan Laptop Fiend
    Also I didn't discover this until recently but any hotfix driver will work without modding. But if you can use @j95 awesome drivers that is the way to go.
    Mr. Fox and vulcan78 like this.
