Alienware M18x R2 PCIe speed stuck at x1 3.0
Discussion in 'Alienware 18 and M18x' started by Mikkel Eriksen, Nov 13, 2018.
  1. Mikkel Eriksen
    Mikkel Eriksen Newbie
    Hello.
    Been using a GTX 870M for some time and decided to upgrade to a GTX 980M.
    installation went good but i noticed my PCIe speed is stuck at X1 3.0
    • Windows 10
    • Using BIOS A13
    • GPU tested under load.
    • using nvidia driver 416.81
    • 980M VBIOS 84.04.2F.00.79
    • GPU-Z Reports it supports PCIe X16 3.0
    anyone experienced the same issue ?
    Best Regards
    Mikkel E.
  2. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Are you in SG or PEG mode?
  3. Khenglish
    Khenglish Notebook Deity
    Clean off the GPU's mxm connector with rubbing alcohol. The slightest film on the pci-e pins will prevent it from connecting properly.
    Ashtrix likes this.
  4. Mikkel Eriksen
    Im using stock A13 BIOS. there is no options for either SG or PEG.
    If I want to change those settings i need to flash A12 modded BIOS right ?
    I will try to clean the MXM connector tomorrow :)
  5. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Easy way to check, open device manager and see if only Nvidia GPU is present or also intel GPU.
  6. Mikkel Eriksen
    only GTX 980M is present
  7. ssj92
    ssj92 Neutron Star
    How are you measuring that the system is running at x1 speeds?
  8. Mikkel Eriksen
  9. Mikkel Eriksen
  10. ssj92
    ssj92 Neutron Star
    Maybe I missed it but how exactly are you determining it's for sure running at x1 speeds?
