Alienware M18x R1 Upgrade... again
Discussion in 'Alienware 18 and M18x' started by Herpnasty, Dec 12, 2017.
Is GTX 780 the best GPU upgrade for a M18x R1?
Poll closed Jan 11, 2018.
  1. Yes
    75.0%
  2. No
    25.0%
  1. GodlikeRU
    GodlikeRU Notebook Deity
    Second fan has different temperature table. It starts spinning on 62C or something like that. Unless your GPUs exceeds 85C it's fine.
    For pad thickness and tutorial check my signature. I did it before.
    Vaeron likes this.
  2. TheDantee
    TheDantee Notebook Evangelist
    Ah ok I run my fans max all the time with a program called HWInfo64 (Disable EC Support) as I have always preferred performance over a little bit of sound, I use my PC with headphones on so u never hear it anyway
    Sent from my ONEPLUS A5000 using Tapatalk
  3. Vaeron
    Vaeron Notebook Evangelist
    That clears things up. I thought it was some weird temp. issue. What's the reason behind it?
  4. GodlikeRU
    I don't know. Maybe they wanted to prevent turning on 2nd fan randomly while in Windows.
