Alienware M18X order advice
Discussion in 'Alienware 18 and M18x' started by Speedy Gonzalez, Apr 20, 2011.
  1. cookinwitdiesel
    cookinwitdiesel Retired Bencher
    I would not plan on being able to put an Ivy Bridge CPU in an M18x
    That will most likely result in your being dissapointed. There will more than likely be a BIOS block (if not physical difference - like socket M vs socket P, bother were 478 pins but different physically)
  2. sticky
    sticky Notebook Consultant
  3. FXi
    FXi Notebook Deity
    Yep count on it NOT happening and just be pleasantly surprised if it does. Indications are that it may fit, but no promises can be made at this stage. 20% more CPU speed and DX11 on the IGP would be wonderful though...
  4. JimmyC
    JimmyC Notebook Consultant
    That's exactly the build I'm eyeing up, but with 3 yr warranty.
  5. pmassey31545
    pmassey31545 Whats the mission sir?
    Is the price difference really that much?
  6. cookinwitdiesel
    Should be about that. $600-$700 over what the 2820qm would cost following past trends
  7. pmassey31545
    Ouch. Might be selling an R3 with a 2720 in it (if you know what I mean)
  8. NYC Drifter
    NYC Drifter Notebook Evangelist
  9. JimmyC
    Quick question about the name plate - I see it screws on, can it be easily removed without leaving a hole? I'd love to put a name on it but it won't mean jack to the person I eventually sell it to...
  10. JTOverath
    JTOverath Notebook Evangelist
    There should be case underneath.
