alienware m17x r4 no 3d vision after gpu upgrade
Discussion in 'Alienware' started by dylandog90, Jun 10, 2018.
  1. dylandog90
    dylandog90 Newbie
    Hello to all,
    I have an alienware m17x r4 120hz display.
    a few days ago I was forced to replace my gtx 660m because it was broken with a gtx 765m, and was mounted and I installed the modified drivers of @Mr. Fox .
    my problem now and I lost the voice "set 3d stereoscopic" from the nvidia control panel, what should I do to be able to use it?Do I have to do something on the monitor's edid? on the bios?and just a driver problem?
    thanks to those who will answer me
  2. Mr. Fox
    The modded driver doesn't support that. So you would need to use a driver that does not have that support removed.
  3. dylandog90
    dylandog90 Newbie
    thank you very much for the quick reply @Mr. Fox .
    any idea on where to find these drivers?
  4. Mr. Fox
  5. dylandog90
    dylandog90 Newbie
    thanks again @Mr. Fox .
    so can I try to download the normal nvidia drivers from the official website? or try the j95 drivers? Which of your downloads should I choose? I mount windows 7
  6. Mr. Fox
    I use exclusively @j95 GeForce driver mods, so I would use his. Just follow the instructions closely with exception of deleting the 3DVision folders. If that doesn't work it might take a special mod, but I would try that first.
    If the stock NVIDIA drivers don't work, you can still use the @j95 INF mods and not delete the worthless crap folders.
  7. dylandog90
    dylandog90 Newbie
    thanks again for your help.
    I will try as soon as I have some time and I will let you know as soon as possible
    thanks for the support
    Mr. Fox likes this.
