Alienware M17x R4 GPU VRM cooling solution!
Discussion in 'Alienware 17 and M17x' started by Johndill, May 23, 2019.
  1. VoodooBane
    VoodooBane Notebook Consultant
    Really need a cnc machine to drill the vent or hole at and Angel. I know what u mean
    Sent from my SAMSUNG-SM-G928A using Tapatalk
  2. nforce4max
    nforce4max Notebook Consultant
    When possible I just use thermal pads on the opposing side of the vrms (other side of the mxm card) and that usually drops the temps a bit. I still kinda like this card for simple tinkering though I wish I had some infs to use it in the m15x and m17x r2 with win 10.
  3. VoodooBane
    Hey you the ranger has a vent there alrdy >:D Lol.
    Also a good way to go about making a vent is to 3d print one with slick using polycarbonate canton fiber branded by Priline. Then as the hexagon metal mesh and just expoxy it over the bad hack job via cutting the square hole woth to a dremel. But this would make it look really legit!
  4. Johndill
    Johndill Notebook Consultant
  5. Henrik9979
    Henrik9979 Notebook Enthusiast
    You should have used the same connection from the GPU fan, that way it will spin up and down together with gpu load.
