Alienware M17x R4 Gloss White
Discussion in 'Alienware 17 and M17x' started by Maxware79, Jan 4, 2021.
  1. aconix
    aconix Notebook Guru
    Indeed my friend, this post from @Maxware79 made me think to get rid of the rubber thing any easy way to do it?
    Enviado do meu SM-N960F através do Tapatalk
  2. Maxware79
    Maxware79 Notebook Deity
    Do you mean the soft-touch?
    aconix likes this.
  3. aconix
    Yes the rubber cover, the soft-touch is still in good condition on the rest pad for example but on the screen(back) it became more like a glue
  4. Maxware79
    To remove the soft-touch on the lid (or anywhere else) you need to use a solvent and a plastic scraping tool. It is like a clear resin that is applied to the black plastic underneath. It takes a long time and is messy. It's much easier to buy a brand new one from ebay for around $32-40USD.
    You can just paint over the soft-touch and it comes out pretty good if done properly.
    aconix likes this.
  5. aconix
    Awesome, thank you
    Mr. Fox and Maxware79 like this.
  6. Maxware79
    aconix likes this.
  7. DugiHowser
    DugiHowser Notebook Enthusiast
    WOW Amazing job!! I was thinking of doing something very similar. What paint brand did you use and did you powder coat the metal shell?
  8. Maxware79
    Thanks. I prefer to use Rust-Oleum 2x Ultra Cover spray paint. Unfortunately there's a huge shortage of their products in Australia right now which has made things difficult. I just use a primer, colour and then clear coat. I wet sand with various grit papers between coats and then a buff/polish at the end.
  9. DugiHowser
    Very cool and thanks for the tip.
  10. Maxware79
    No problemo. I also sometimes use Dupli-color colour match paint for some projects, if I want a more metallic look. I'm just about to start an M18x R2 and I'll probably go for a metallic yellow or green.
    [​IMG][​IMG]
