Alienware m17x r3 - battery problems
Discussion in 'Alienware 17 and M17x' started by Kamil Ilyas, Feb 17, 2015.
  1. Kamil Ilyas
    Kamil Ilyas Newbie
    Hey everyone,
    So I bought a used alienware a couple of months ago, was and is working fine, except for one problem. A couple of weeks back I came home and turned it on, but after the first Klipsch loader a message comes in the BIOS format before the windows loader:
    WARNING: The battery cannot be identified.
    THe will be unable to charge this battery.
    Strike the F1 key to continue, F2 to run the setup utility
    I dont know how it happened or how it came up, I remember a full accidental drain of the battery before the problem, but I also fully charged it afterwards, this i just mentioned coz of the static charge issues in alienwares, I have tried many and all solutions available on the internet but none proved fruitful, I dont know what to do next, any suggestion would be greatly appreciated.
    Regards,
  2. Alienware-L_Porras
    It seems like the battery needs a replacement. Have you tried a battery status monitor?
  3. Kamil Ilyas
    Kamil Ilyas Newbie
    Thank you for your response, how can I be sure if the battery needs replacement or not ? plus also how to verify if the power pack is okay or not ?
    Will try the battery status monitor today, thanks again.
    Regards,
  4. Alienware-L_Porras
    Because the error is strictly related with the battery. If the computer works with the battery unplugged and only the adapter, then the adapter is fine.
  5. Kamil Ilyas
    Kamil Ilyas Newbie
    yeah thanks that was my hunch too as the laptop runs on the direct power supply, will run the battery status monitor now
