Alienware m14x Making Insane Beeping noise that won't stop (won't boot)
Discussion in 'Alienware 14 and M14x' started by XxAlbertoxX, Nov 26, 2012.
  1. XxAlbertoxX
    XxAlbertoxX Notebook Consultant
    So my alienware m14x that I purchased my 1year ago, just started making multiple, sequential, beeping noises upon start-up.
    To be honest, it did this about 1+ week ago, but I did the "system repair" and restarted and it somehow "fixed" itself (for the moment atleast) and allowed me to log- on to windows 7 until now.
    It started again this morning, despite working last night. I shut down the computer via the "shut down " option in the start panel.
    I tried doing the system repair option & memory diagnostic on the BIOS screen. Doesn't seem like anything helps.
    It keeps beeping, and it pretty much won't stop. Is it the motherboard (hardware), or maybe software? over heating?
    I really REALLY wanted to delete that stuff before I send anything in....
    Any advice guys? I would very greatly appreciate it.
  2. Tsunade_Hime
    Tsunade_Hime such bacon. wow
    Did you count the amount of beeps? Dell/Alienware has a code for the # of beeps. Did you have onsite warranty? Alienware will send someone to your home.
  3. XxAlbertoxX
    It's an unlimited # of beeps... it never stops... it will beep, 100times or even more just continuously like an alarm clock...
    I purchased the 2 year plan, I would have to log into to Dell to see or check the box with receipt which is downstairs still I believe.
    I was just seeing if anyone knows what the multiple beeps are, since there is a set "number" or "pattern"
    And I had stuff on the HDD that I wanted to delete before anyone services the computer ya know :p
  4. ejohnson
    ejohnson Is that lemon zest?
    Motherboard failure is my guess.
  5. Mastaa
    Mastaa Notebook Consultant
    You can still remove your HDD and connect it to another computer to remove your "private" stuff you don't want anyone to see, if you really think this is necessary :D
  6. digitalmo
    digitalmo Notebook Consultant
    Sound like the mobo is fried or something of that nature.
    Just take the bottom cover off and remove the HDD before you send it in. They may refuse to service it without all the original parts in, though? So the ideal is to remove the drive, install in another computer, format, reinstall in AW before you send it for service.
    Good Luck!
    Maybe they will give you an r2?
  7. digitalmo
  8. Alienware-L_Porras
    Do you have anything attached to it? An external keyboard or ODD or something?
  9. HavocATX
    HavocATX Notebook Guru
    Does it beep in the bios screen or only when in windows?
    If not in the bios, boot to the Windows Disc. Does it beep then?
  10. Sn1PeR
    Sn1PeR Notebook Enthusiast
    Mine started doing the exact same thing this past weekend (R2 here though). I believe it has something to do with the battery. I was able to get mine to boot by holding down the power button to shut it down, and then plugging in the power cable before attempting to boot again. Oddly enough I had the problem again and it would not boot until I unplugged the power cable. I just had the problem again today when resuming the laptop from hibernation, holding the power button and starting it again solved the issue.
    I also was getting a continuous beep that never stopped.
    I should add that my problem started when I hit control+alt+delete during the windows 8 bootup (missed getting into the bios - was on the way to turn off the cpu turbo feature).
