Alienware M11x R3 initial impression
Discussion in 'Alienware M11x' started by howard911s, Apr 28, 2011.
  1. clodderes
    clodderes Notebook Enthusiast
    my graphic score for the R2 is only 3.1, it's really because of optimus
  2. i has m11x
    i has m11x Notebook Evangelist
    On a system with Optimus, the WEI uses the Intel gpu for the Aero score and the Nvidia gpu for the gaming score. The gaming portion of the test enables the Nvidia gpu to kick in, while the Aero desktop test isn't demanding so the Intel gpu is used. The R1 doesn't have the auto graphics switching ability of Optimus, so the user most likely has the laptop set to use the Nvidia gpu during the test, giving it a much higher Aero score than the R2 or R3 will get.
  3. Augusta
    Augusta Notebook Consultant
    Thanks for the post op.
  4. yelohotshot
    yelohotshot Notebook Consultant
    The graphics score for the R2 is at a mesely 2.3. This is the Intel Graphics not the NVidia, being an R2 Optimus, what would the Nvidia 335m score?
  5. howard911s
    howard911s Notebook Deity NBR Reviewer
    Not the slim one, this is a new one, it is bulkier than R2's adapter but not too big. If you have used HP laptop its the same size
  6. howard911s
    R3's fan under full load is MUCH louder than R2's under full load
  7. anthonykit
    anthonykit Notebook Consultant
    "R3's fan under full load is MUCH louder then R2's under full load".
    Proof that a case redesign is needed going forward to accomodate even faster gpu's.
    My money is one a new case for the R4.
  8. DavyGT
    DavyGT Overclocker
    What were the temperatures?
  9. oakley1261
    oakley1261 Notebook Geek
    So.... You want a bigger case design for the m11x now? I suspect if there is a redesign of the case, it will be thinner. But if current hardware is unable to support that, it will most likely stay the same size and design for a while.
  10. anthonykit
    Not necessarly.
    The new case will require reworking everything to improve airflow including possible making the battery smaller or, making the battery non-removable to save even more space.
    Friend, the 2 month old m17x is approx 1/4" thinner with an even faster gpu then the prev one.
    It just requires that Dell engineers do something more than just add a new chipset and processor. Its more work/money involved.
    If no one has higher standards and demand more from Dell than they have no reason to work harder.
    Its okay if you don't join my bandwagon cause when the R4 comes out with a new chassis I can claim all the credit for it myself :)
