Alienware area51 m15x 32bit help
Discussion in 'Alienware Area-51/Aurora and Legacy Systems' started by MAX765, Apr 25, 2019.
  1. MAX765
    MAX765 Newbie
    Hi wondering if anyone would be-able to help me i just got a used Alienware area51 m15x and the cd that came with the drivers does not have the Command Center in it just OSD so i saw this post http://forum.notebookreview.com/threads/m15x-mini-myhive.342331/ and it has links to Command Center v. 1017 and Command Center v. 1028 (x32) but there dead i manged to get Command Center v. 1033 but it does not work it said it didn't match my processor so i was wondering if anyone had links to v1017 or v1028 i have 32bit windows vista thanks
  2. protivakid
    protivakid Notebook Evangelist
    Did you try the vesion in my post? http://forum.notebookreview.com/threads/alienware-area-51-m15x-r1-working-drivers.805105/
  3. MAX765
    MAX765 Newbie
    the download link is for version 1033 and yeah i tried it said it didn't match my processor
  4. protivakid
    These worked for my m15x. Which version do you have? The pre-dell Alienware's or the Dell takeover alienwares? My drivers are for the 2008 pre-dell units
  5. MAX765
    MAX765 Newbie
    It just kept saying it could not install because of my processor i have a Intel core 2 duo T8300 2.4ghz
  6. protivakid
    Are you running a 64 or 32-bit version of Windows? My guess is the Command Center might by 64-bit only
  7. MAX765
    MAX765 Newbie
    i am running the 32 bit version
  8. protivakid
    Ahh ok, then that's probably why you are receiving the "Processor Architecture" error. Any reason you don't want to run 64-bit? When I bought my m15x I'm not sure I was even given the option for 32-bit. You may have to pick between 32-bit or 64 & working Command Center
