Alienware 23inch monitor
Discussion in 'Alienware' started by Throbin, Mar 17, 2013.
  1. Throbin
    Throbin Notebook Consultant
    Thinking of getting it for my m18x what cable would you guys advise for best fps and that.
    Cheers simon
  2. katalin_2003
    katalin_2003 NBR Spectre Super Moderator
    To benefit from this monitor's capabilities, while plugged in to your laptop, you'll need an active displaypory to dual link DVI adapter and a mini displayport to displayport cable.
  3. Throbin
    Can I get a link to one for sale? Can't find one even on google lol
  4. vsg28
    vsg28 Notebook Consultant
  5. Throbin
    Not doing multi display setup just using this as my main monitor
  6. katalin_2003
    Yes, that's perfect, no need for a miniDP to DP adapter.
    I understand, but using anything else besides an active adapter will limit you to 60Hz and unless you want 120hz for 3D, i don't recommend this monitor.
  7. Throbin
  8. Mr. Fox
  9. katalin_2003
    The one that vsg28 linked is perfect and a cleaner solution, you won't need anything else but be careful the one from your first link is not Dual link DVI, the second one is ok but you'll need a miniDP to DP cable too since the M18x has a miniDP.
  10. steviejones133
    steviejones133 Notebook Nobel Laureate
