Alienware 18 with MSI GTX 1070 issues
Discussion in 'Alienware 18 and M18x' started by razor0601, Sep 26, 2019.
  1. razor0601
    razor0601 Notebook Evangelist
    AW CC also didn‘t work. Do you have a No GSync card?
  2. MagicMike
    MagicMike Notebook Consultant
    Not sure how I would check that? It's an MSI card.
  3. razor0601
    In gpu-z. 1BA1 is non GSync. 1BE1 is Gsync
  4. MagicMike
    Ok, mine is non gsync then as it's a 1ba1.
  5. razor0601
    So maybe that’s the fault?
    Because you have the same AW18 with the same unlocked Bios?
  6. MagicMike
    Mine is a m18x r2 but the throttling issues occur in both cases.
    I feel for you, really, I have gone through so many "fixes" I was beginning to think i would never get to the bottom of it, i thought about going dual psu mod, i have must have repasted / reseated the gpu about a dozen times thinking I might have modded something incorrectly but in the end what worked was the sleep wake fix and raising the rear of the tablet up to optimize air intake...
    I am still pondering the dual psu mod as I am curious what effect it will have but I ain't spending 780 euros on a new one...
    Good luck bro, hope you get to the bottom of it.
  7. MagicMike
    Did you manage to sort out the throttling issues?
  8. razor0601
    No, I sold the AW18 with a 980M.
  9. Ferit Tuzer
    Ferit Tuzer Newbie
    was it working fine with a 980m or was that throttled too? the tdp's are similar. i'm thinking of upgrading to a 970m or 980m.
  10. razor0601
    With one 980m it works fine
