Alienware 18 with MSI GTX 1070 issues
Discussion in 'Alienware 18 and M18x' started by razor0601, Sep 26, 2019.
  1. razor0601
    razor0601 Notebook Consultant
    Hello at all. I have an MSI GTX 1070 Running in my AW18. VBIos is 86.04.26.00.06
    In any Benchmark The 1070 throttles between 1000-1600MHz. I tried many various settings in the Driver and Bios. Nothing helps.
    Does anyone have an idea what I can do to get the card fully working?
  2. MagicMike
    MagicMike Notebook Consultant
    I had a similar issue in my m18x, it seems the only thing that has reliably helped thus far is the sleep and wake trick that Mr.Fox told me about.
    So you put the baby to sleep, wait a couple minutes, and wake it. Simple right:)
    You have to sever any links to either Dell EC or Compal EC in Hwinfo64 if you are using it, I.e. disable monitoring them (and remove the tick in settings). The trick never worked for me whilst that was on.
    It may take a few attempts too.
    Hope this helps!
    M18x-oldie likes this.
  3. razor0601
    Ok, I will try it.
    Doesn‘t work for me. Put into sleep for 15 minutes. I don‘t use HWInfo64.
    Also switched to IGFX and back to SG. No changes
    Any other solution?
  4. TheReciever
    TheReciever D! For Dragon!
    Start using hwinfo64 and get the limit reasons.
  5. MagicMike
    Try this although it only worked for me once:
    * right click on desktop and go into Nvidia settings
    * then into 3d settings
    * then find power management and change to prefer maximum power from whatever the default is
  6. razor0601
    That was the first thing I tried.
    MagicMike likes this.
  7. razor0601
    Now I have HWInfo64. Card goes up to 113W and fell down to 50/60w. And says sometimes performance power limit
  8. MagicMike
    Definitely throttles, mine goes up to 135W in TimeSpy. Have you tried uninstalling AWCC?
  9. razor0601
    Alienware command center?
    Which GTX 1070 with which VBios do you have?
  10. MagicMike
    Yes.
    My vbios is 86.04.25.00.41
