Alienware 18 various mods + eGpu
Discussion in 'Alienware 18 and M18x' started by giogrig, Sep 30, 2017.
  1. giogrig
    giogrig Notebook Enthusiast
    thx I will definitely have a look into it, and yes my bios version is A12 so should be easy :)
  2. giogrig
    Recently i flashed the a12 Bios Unlocked version and indeed i could find the SG option here is a pic. At the moment i still have a sli of gtx765m installed, if i switch to SG it's still going to be able to boot and run properly ?
      File size:
      474.5 KB
      195
  3. ColaMonster
    ColaMonster Notebook Consultant
    Basically worst case it doesnt post after swapping to SG or a different bios option, pull the battery, pull the cmos, and then hold the power button for a little bit, put the batteries back in, and try again. :) I had to do that alot while getting my 1060 working, since i was testing different bios options while trying to figure out why optimus wasnt working. (Was the nvidia driver lmao)
  4. giogrig
    I had a go and yes boot’s properly, will only use the integrated intel though, but the good thing is that works as intended, thanks
  5. ColaMonster
    Thats with two graphics cards in right? does it detect them both? But SG mode is switchable, it should try to use your graphics card if a load is put on, but if it doesnt, its a driver issue.(which could be because optimus and sli dont work together well, idk) when installing my 1060 i had trouble getting it to use the graphics card instead of integrated, and i just had to finish modding the graphics driver :)
  6. giogrig
    Yes is with two graphics card in, that's my guess when i load the gpu the nvidia's doesn't work therefore i think is a driver related issue. like in you're case
  7. tik987
    tik987 Notebook Enthusiast
    question, old thread I know, but would a 18 inch uhd lcd work for this laptop? found a Chinese seller on ebay selling one. same 40 pin lcd and size fitment. any info would be great. thanks
  8. Rengsey R. H. Jr.
    No. The laptop don’t have edp connection.
    Do you have a link to that lcd ?
  9. tik987
