Alienware 18, HDMI IN Port, Help !
Discussion in 'Alienware 18 and M18x' started by giogrig, Jul 14, 2019.
  1. giogrig
    giogrig Notebook Enthusiast
    Hello forum,
    in short the HDMI IN port on my mid 2013 Alienware 18 doesn't work any longer. The HDMI OUT works just fine. Roughly 9 months ago on windows 10 i was able to use my HDMI IN using the same setup and cables with no issues at all 9 months later the port just doesn't work any longer. I did several tests and researches in the past 7 days, and doesn't look to be the windows version, i did a fresh install of win 10, 1703, (no luck) but if related could be a nvidia or intel hd driver ?! or maybe just a hardware issue. Now hopefully someone here knows what are the drivers that are responsible for the HDMI IN port ??
  2. GodlikeRU
    GodlikeRU Notebook Deity
    I think it may be hardware issue. I suggest to get a LiveUSB Ubuntu Linux, boot it and test it HDMI In works, it should.
  3. giogrig
    I Will give it a try
  4. giogrig
    The HDMI IN option should be enabled in the display tab ?
  5. GodlikeRU
    Which display tab?
  6. giogrig
    settings -> display tab
  7. GodlikeRU
    There's no such option on M18xR1. Sorry for long delay im not here often
  8. giogrig
    the question was when you're in ubuntu how do switch to hdmi in ?? in windows i press "f9" which stands for hdmi in
  9. GodlikeRU
    FN+F8 on M18xR1
  10. ssj92
    ssj92 Neutron Star
