Alienware 18 Battery Replacement
Discussion in 'Alienware 18 and M18x' started by @tomX, Jan 31, 2021.
  1. senso
    senso Notebook Deity
    Just buy brand new cells from NKON with tab pre-soldered, they will cost you the same.
  2. @tomX
    @tomX Notebook Evangelist
    none of the ones NKON sells with tabs are protected...
  3. @tomX
    This is how the battery looks inside:
    The cells are Samsung ICR18650-30B - 3000 mAh
    In the end and after some web research, these are the cells I ended up putting in my top list :
    1) Panasonic NCR18650B 3400 mAh
    https://www.akkuteile.de/lithium-io...r18650b-3-6v-3400mah-loetfahne-u_1006391_1662
    https://www.batteriesplus.co.uk/aca...3.7-V-3400-mAh-Lithium-cell-2081.html#SID=562
    https://www.akkula.fi/epages/akkula...Shops/20110228-11092-27846-1/Products/13335-Z
    Cons: unprotected
    Pros: brand + quality + power + tags
    2) Sanyo / Panasonic NCR18650GA 3.6V - 3.7V 3500mAh
    https://www.akkuteile.de/lithium-io...ga-3-6v-3-7v-3500mah-loetfahne-u_1006761_1688
    Cons: unprotected
    Pros: brand + quality + power + price + tags
    3) LG INR18650MJ1 - 3500mAh
    https://www.akkuteile.de/lithium-io...3-7v-10a-li-ion-akku-loetfahne-u_1006971_1700
    Cons: unprotected
    4) Panasonic NCR18650A 3100 mAh
    https://www.akkuteile.de/lithium-io...r18650a-3-6v-3100mah-loetfahne-u_1006061_1640
    Cons: unprotected
    Pros: brand + quality + tags
    5) Samsung INR18650-29e 2850 mAh
    https://enerprof.de/en/li-ion-batte...-29e-tags-u-form-li-ion-3.62v-2850mah/3c?c=43
    https://eu.nkon.nl/rechargeable/li-...-inr18650-29e-2900mah-e6-8-25a-met-u-tag.html
    Cons: unprotected + lower power
    6) Soshine Li-ion 18650 Protected Battery 3600mAh
    https://www.gearbest.com/batteries-and-cases/pp_1113234.html?wid=1433363
    Cons: button top instead of solder tags
    Pros: brand + quality + power + protected
    Good battery test index:
    https://lygte-info.dk/info/batteryIndex.html
    Ashtrix and Maxware79 like this.
  4. @tomX
    Sadly it's a no go as it was tested and is dead...
  5. Ashtrix
    Ashtrix ψυχή υπεροχή
    Finally my Simplo battery pack from Dell which was a spare that I ordered 4-5 years back is now permanently damaged, that's what the machine showed today. Suddenly the battery was 0% and I tried to make it express charge and normal charge, it wouldn't. So I tried to remove the connector and powered the machine on, that message came. It has been a good run and a very reliable hardware. Now I will probably have to soon try to learn more on this and perform this repair.
    ll_r1d0_ll likes this.
  6. xKilXlerx
    xKilXlerx Notebook Geek
    Did you even try to reset the battery cycle count when the new cells were installed?
  7. Unfaehig
    Unfaehig Newbie
    Did your cell change work?
    Often hear laptop battery controller be a problem, if you change cells and new cells gets reported as faulty.
    Did you something special like keep cells connected parallel, to out play that?
