Alienware 18 8 beeps no post.
Discussion in 'Alienware 18 and M18x' started by Raja786, Dec 16, 2018.
  1. Raja786
    Raja786 Notebook Consultant
    Hi recently upgraded ram from 16GB to 32GB & GPU from 980m sli to a single 1070. Been working fine since until yesterday when I went into bios and went into the performance tab and enabled oc lvl 1 for CPU. Saved and exited and got black screen and no boot but could hear fans running and all lights were on. So I force shutdown and turned back on and that’s when the 8 beeps started. So I tried a ram hot swap to no avail. Then I opened laptop and drained all power and tried resetting bios via cmos battery but still 8 beeps. Then I removed HDD all ram and GPU and put back together and turned on and started getting 4 beeps. Turned of and put everything back in and fired up and still 8 beeps. So last night I removed battery and cmos battery and left over night. This morning put cmos battery and battery back in and tried booting and was getting 2 beeps and system auto shutdown. Then booted back up and 8 beeps again.
    Does anyone have an idea of what could be the problem. I’m 99% sure the GPU is fine as I’ve had it for a few days and it was working perfectly. Temp didn’t exceed 75c while gaming.
    All input welcome.
  2. marcomarc
    marcomarc Notebook Enthusiast
    Hello,
    as i see you are fighting too with your motherboard.
    I would try a reset without the discrete GPU.
    What you need with the reset processing is 5 beeps. As long as you get only 4 you wont get ur system back
  3. Raja786
    I removed the GPU and tried but it did not boot.
  4. marcomarc
    theoretically, 8 beeps is a LCD failure
  5. Raja786
    Yes. That’s what dell site say. But it could be anything from the motherboard to the actual GPU.
  6. Danishblunt
    Danishblunt Guest
    @Raidriar
    ANy idea how to make the board want to work again? Fickle AW 18 boards aren't exacly uncommon.
  7. Raja786
    All done. You was right Danish. Because I had a 1070 and using SG Mode when I reset bios it switched back to PEG Mode hence why I was getting 8 beeps. Removed 1070 and installed a 980m so I was able to boot. Changed back to SG mode and installed 1070 again and now it’s up and running. Thanks for all the help and replies.
  8. ssj92
    ssj92 Neutron Star
    It's very useful to keep a PEG supported GPU around, even if it's a crappy GPU or one that doesn't work under 3D loads.
  9. Raja786
    Yes I was going to sell my 980m but now I’m keeping it just incase
  10. ssj92
    ssj92 Neutron Star
    You can sell the 980M and just buy a cheap card that costs like $40-50 for PEG.
    M18x-oldie likes this.
