  1. Yes.
    302 vote(s)
    77.0%
  2. No.
    19 vote(s)
    4.8%
  3. Maybe.
    71 vote(s)
    18.1%
  1. SoldierRBT
    SoldierRBT Notebook Geek
    I didn't repad it, just repaste. If I repad, will it improve the uneven core temperatures? before repaste the uneven core temps were about 20C, after repaste is 7-9C. I repaste with the X method in both CPU and GPU. GPU now max temp is 65C, that's 4C lower than stock paste.
    I'm testing my OC with OCCT and core#0 failed after 1hour. Change the voltage to -110mv to see if it can past the 1hour test. Max temp in OCCT is 78C with 4.1GHz all cores
  2. Altairwarz
    Altairwarz Notebook Enthusiast
    I have repadded the gpu side of my unit and have 9 - 12C differential at stock clocks. But when i OC cores 0 1 and 2 hit upto 99C and avg around 85 while core 3 hit a max of 85C and avg at 74C and there’s upto 20C differentials.
    At stock clocks my CPU temps rarely go beyond 85C and usually average at 70C with a -135mv undervolt.
    I will repad the CPU side soon that might solve the issue.
    My GPU never goes above 65C.
  3. SoldierRBT
    Let me know if repadding the CPU side improve the uneven core temps. I'd like to reduce my 7C-9C differential to 3C-5C.
    Altairwarz likes this.
  4. TheSpudLord
    TheSpudLord Newbie
    So I just recently repasted with conductonaut, and i'm not getting the temps I was expecting, and in some cases, things have been even worse. I'm pretty sure my issues are with the thermal pads, but before I take this thing apart again, I wanted to get some input. So, from what i've gathered, differing core temps are a pretty common issue, but for me, im having almost a 20- 30 degree difference between cores 0 2 and 1 3. at idle, cores 0 2 hang around 75, and cores 1 3 hang around 60, but under load, cores 0 2 throttle at 99 while 1 3 stay around 75. I also get readings that that the CPU package and IA cores hang around 75@idle but are hitting 105@Max under load. The Package/Ring also reads as thermal throttling under load too. I'm pretty new to this so any help I can get would be great, thanks!
  5. rinneh
    rinneh Notebook Prophet
    Thats definitely a problem with the pads but maybe your heatsink is a bit of a dud to begin with.
  6. Engineer-94
    Engineer-94 Notebook Enthusiast
    What if I use it in a very little amount ? I got two choices: 1. Thermal grizzly kryonaut, 2. Arctic Silver.
    Really confused. What to do?
  7. Mobius 1
    Just leave the really thin thermal pad alone, you don't need to change that.
    rinneh and Vistar Shook like this.
  8. Engineer-94
    I don't have that thin thermal pad there, my machine was shipped before Oct 2017? And that is the real problem.
  9. Mobius 1
    So you have 0.5mm pad?
    Just remove it, the chokes don't really need cooling.
    If you would like to use Thermal paste for now, that would work too.
    Vistar Shook likes this.
  10. Engineer-94
    So can I use kryonaut in 0.1 mm space? Is it dangerous?
