  1. Yes.
    289 vote(s)
    76.1%
  2. No.
    19 vote(s)
    5.0%
  3. Maybe.
    72 vote(s)
    18.9%
  1. rinneh
    rinneh Notebook Prophet
    Hmm that sucks to hear. That means it isnt a great solution after all.
    Pete Light likes this.
  2. abhay4sengars
    abhay4sengars Notebook Enthusiast
    For someone who is new to this, how would you suggest to cover such thin gaps? 0.1-0.2mm ones
  3. rinneh
    0.2mm thermal pads but those are hard to come by.
  4. Pete Light
    Pete Light Notebook Deity
    0.1mm thermal tape
    Sent from my SM-G935F using Tapatalk
  5. crazy08
    crazy08 Notebook Enthusiast
    for the 1.5mm thickness stock pads is it okay to stack a 1mm and a 0.5mm pad together to achieve the thickness?
    Or even 3x 0.5mm pads?
    Does that significantly degrade their performance?
  6. rinneh
    Its not ideal but it can be done if the pads are not of a dry type. Arctic pads for example are okay for this.
  7. c69k
    c69k Notebook Deity
  8. JRBruett
    JRBruett Notebook Enthusiast
    Oh, My apologies. I should have been paying attention.
    I hope these work better.
    https://imgur.com/7AtfPIi
    https://imgur.com/BxD4nQn
    Falkentyne likes this.
  9. crazy08
    Fujipoly?
    Sent from my SM-N950U1 using Tapatalk
  10. BartyB
    BartyB Newbie
    My Alienware 17 R4 w/ 1080 and7820HK when I stress test it the temps are showing fine but yet after say 5 mins the stress test or while gaming will just stop working and it will say "game has stopped working" or unigine just stops working.. I am going to hope and assume it is temp related and that doing a repaste and repad will solve the issue.
    So when it comes to the thermal pads. I take off all the stock ones and replace them with the better thermal pads.. should I put the HS back on (after I clear off the thermal paste) and make sure all the thermal pads have impressions so I know they are all making good contact and if so then put on the new thermal paste? Or will lifting heat sink back up "ruin" the pad?
    Also for the PCH mod.. where can I get the fin, I don't see any that are less than 5mm. Also what glue do you use?
    Lastly I saw someone post something about lapping the heatsinks before using liquid metal? Is that step necessary? I'm thinking about using LM I'm just wary since I have never even heard about it before nvm using it.
