  1. Yes.
    302 vote(s)
    77.0%
  2. No.
    19 vote(s)
    4.8%
  3. Maybe.
    71 vote(s)
    18.1%
  1. N3V3RB3LIEV3
    N3V3RB3LIEV3 Notebook Enthusiast
    Is there any gap between the heatsink and the cpu/gpu? Do you think I could fit in a copper shim?
  2. iunlock
    iunlock 7980XE @ 5.4GHz
    From my observation and from seeing the results of the liquid metal and core temps, there is no room to fit a shim between the die and heat sink. I would not recommend it.
    One or two things will happen:
    1. The copper shim, depending on how think it is will fit, but you'll compromise your thermal pads so you'll need to get thicker pads all around to have your VRM's make proper contact.
    or
    2. The shim won't fit and heat sink will not screw in place properly like it is designed to, leading into the first issue above.
    N3V3RB3LIEV3 likes this.
  3. N3V3RB3LIEV3
    Thank you for the help! Looks like the only way now is to repaste and undervolt the crap out of the cpu and gpu. Keeping fingers crossed for good temps...
  4. 0Style
    0Style Notebook Consultant
    Has anyone ordered th 15r3 1070/6820HK from HID with the liquid metal repaste? How are the temps?
  5. raiden87
    raiden87 Notebook Evangelist
    i have the 15r3 with 6820hk and 1070. I posted my temps on the first page
  6. 0Style
    Did you repaste it yourself or used the option from HID? I just don't wanna commit to buying something that's beyond my technical level.. Thanks for your help!
  7. raiden87
    repasted myself, but i am an it specialist and do this everyday (only with fujitsu notebooks :p )
  8. 0Style
    Yeah but that's different. There is no saying if HID would do as good of a job as you did ;/
  9. jeremykrak
    jeremykrak Notebook Guru
    Just did a repaste with IC Diamond. Temps dropped tremendously about 15 degrees (from 95 to 80) in an ADOBE PREMIERE 99% CPU render stress test I created.
  10. Mobius 1
    oh no...
Similar Threads - [Alienware 17R4 15R3]
  1. psoutrage
    677
