Alienware 17R1 Zotac GTX 1060 Upgrade Help
Discussion in 'Alienware 17 and M17x' started by Wolfdogelite, Aug 15, 2017.
  1. Wolfdogelite
    Wolfdogelite Notebook Enthusiast
    So I thought I was really close to finishing this up but it seems I've hit another snag. I'm unable to rewrite the vbios on this GPU with nvflash. I've tried multiple versions of the program, from current to one from April of 2016 based on a random forum post suggestion, with lots of conflicting instructions and guides. On newer versions of nvflash I can get it to recognize the Nvidia GPU, remove protections and even successfully backed up my current vbios, but when I go to update the new vbios it fails with the error: GPU mismatch.
    This is using the command:
    nvflash64 -6 1060backup.rom
    This "-6" should be removing the very check that it's failing on, "Allow firmware and adapter PCI subsystem ID mismatch." I can't see a way around this. I found a couple guides recommending a bootable USB method, but seeing as the bootable USB is ms-dos or freedos based I can't boot from it with my bios settings on UEFI only mode, and I can't switch that to anything else without losing video output to my external screen.
    The one thing I can't seem to follow on these guides is that they want the display device disabled in device manager, but I don't believe that is possible in this case as I would lose all video output since the iGPU will not work with the eDP 120hz panel, and from my understanding it's completely disabled when that panel is connected. It certainly doesn't show up under display devices.
    I'm really curious if @Striker1234 did anything special to get his card to flash or if it was as simple as all the guides make it out to be.
    I'm starting to think I need to find someone with an M17x Rx/ M18x R2 that can boot in UEFI+CSM mode to flash the card to an appropriate vbios and then I would be able to continue with modified drivers in my machine.
    Any suggestions would be greatly appreciated!
  2. Striker1234
    Striker1234 Notebook Consultant
  3. Wolfdogelite
    So I tried it, but it seems like nvflash just will not force the install with this GPU mismatch error. Is there any other way to force the update?
    BTW, did you have to disable the Microsoft Basic Display Adapter in Device Manager before you ran nvflash?
  4. EepoSaurus
    EepoSaurus Notebook Deity
    the surefire way to do it is to get this programmer http://www.ebay.com/itm/USB-TL866CS...454390&hash=item1c59ee0cc3:g:lR0AAOSw4DJYmtMy
    youll need this clip http://www.ebay.com/itm/SOIC8-SOP8-...668772?hash=item44080a4c64:g:5NEAAOSwruhZitBW
    and you should have this 1.8v adapter just to be safe. http://www.ebay.com/itm/1-8V-Adapte...788263?hash=item3aea1bb7e7:g:giwAAOSwUIhZYYx0
    you can flash the bios with this programmer. I do it all the time. requires you remove the card and physically attach the programmer. aside from the mad scientist 80s hacker feel its actually quite simple
    FaTT and Wolfdogelite like this.
  5. Wolfdogelite
    Say no more, this is exactly what I need. Thank you sir, I'm going to order these up right away.
    Also, This tool wouldn't happen to aid in reprogramming a dead panels EDID now, would it?
  6. EepoSaurus
    It is a general programer so if you can connect to it and it has a bios or something to that effect you can flash it
  7. Wolfdogelite
    That is awesome, maybe I can save the 1080p panel I killed in my Precision with it too! Best of all, I now have the tool I need in the event that damn EDID corruption bug crops up again.
    Thanks a lot EepoSaurus!
    EepoSaurus likes this.
