Alienware 17 R4 won't boot. BSODs all over the place. Please help.
Discussion in '2015+ Alienware 13 / 15 / 17' started by haxxN, Feb 21, 2019.
  1. haxxN
    haxxN Notebook Enthusiast
    System is out of warranty, before anyone asks.
    512GB SSD (wiped, no OS)
    1TB HDD (wiped, no OS)
    7820HK
    GTX1080
    Whenever I try to install via bootable USB (win10 image), I get a BSOD after a minute when it prepares files for install.
    Things I've tried:
    - Memtest86+, 24 hours, no error
    - Boot with just the SSD
    - Boot with just the HDD
    - Remove both sticks of RAM, testing with just 1 of both, tested with both
    - Reset CMOS (removed CMOS cable and battery cable, replaced them)
    - Boot from a linux image (linux mint 19, getting a kernel panic as soon as it tries to install)
    - Stress-testing the CPU from Ultimate Boot CD's CPU Burn-In utility (24 hours, no error)
    I'm at my wits end with this, please advise.
  2. Muezick
    Muezick Notebook Consultant
    What is the BSOD message that it gives?
  3. haxxN
    It's never the same message, but I did get those ones:
    IRQL_NOT_GREATER_OR_EQUAL
    TRAP_CAUSE_UNKNOWN
    REFERENCE_BY_POINTER
    BAD_POOL_HEADER
    MEMORY_MANAGEMENT
    KMODE_EXCEPTION_NOT_HANDLED
    and probably a few other ones I'm forgetting about
  4. Muezick
    Tried another win10 installer I guess?
  5. haxxN
    Tried 2 different Win10 images on two different USB sticks, also tried 2 different linux images (linux mint and openSUSE)
  6. Muezick
    so i'm guessing your m.2 port is bad. try moving the ssd over one, or removing it and installing directly to the hdd? sorry i know it says you tried "Booting with just HDD' but i wasn't sure if that meant you tried installing direct to the sata without any m.2 installed or moving to another m.2 port.
  7. haxxN
    tried with just the hdd in without any m.2 to no avail :(
  8. SMOKE_SKULL
    SMOKE_SKULL Notebook Deity
    Is there anything that happened to start this problem?
  9. haxxN
    Not really, I was playing Call of Duty Black Ops 4 when I had a first BSOD, I rebooted then got a second one minutes after. I formatted on the newest Win10 Pro image I coukd get from the media creation tool, proceeded to install all of the available drivers for my system then a couple games and apps. Couple hours later I tried playing Rocket League and BSODed after only 3p secs-1min. Rebooted, BSODed again and never was able to boot after that.
  10. SMOKE_SKULL
    Is there a way to disable the nvidia graphics and run on cpu onboarding or is that disabled on that model? Kinda sounds like a component has failed on the mainboard and is causing a short in the main power? Have you inspected the motherboard carefully for burns or components out of place?
