Alienware 17 r4 not opening
Discussion in '2015+ Alienware 13 / 15 / 17' started by Safa Şahbaz, Mar 29, 2018.
  1. Safa Şahbaz
    Safa Şahbaz Newbie
    Hi,
    I repasted my alienware 17 r4 with thermal grizzly.
    After that I open the laptop and checked the temperature after 5 minutes it's closed himself.
    I removed the backplate and reassemble the ram then I opened again and it worked. I close the backplate and plug the power supply then I push to button I see the lights but after 5 seconds it's closed.
    Can someone help me?
  2. Mobius 1
    dislodged AC power cable?
  3. Safa Şahbaz
    Safa Şahbaz Newbie
    Yes I dislodged power cable
  4. Safa Şahbaz
    Safa Şahbaz Newbie
    I dislodged the cable and I opened the backplate again then reassembly the ram and battery cable and dc cable from motherboard. Pc is working now but probably it will happen again. Gpu temperature is low but Cpu temperature is unstable
  5. Safa Şahbaz
    Safa Şahbaz Newbie
    I closed the laptop and closed the pack plate I trying to open but it's not opening
  6. Mobius 1
    What do you mean it's not opening?
    c69k likes this.
  7. Safa Şahbaz
    Safa Şahbaz Newbie
    When I pushed to button I see the lights but after 5 seconds lights are gone and pc is not opening
    c69k likes this.
  8. nedooo
    nedooo Notebook Consultant
    I guess he means it is not booting, since it is a laptop not a robot, therfore it can't open itself...
    c69k likes this.
  9. XxAcidSnowxX
    XxAcidSnowxX Notebook Consultant
    If you are not seeing the initial Alienware logo it means its shorting. Dissassemble again make sure all ribbon cables are straight. The first time I believe you said it stayed on for 5 min and shut off, that suggests it overheated - that could be that the heatsync was not attached properly, or its lifted in a corner not making contact, check that too when you disassemble.
  10. Alienware-Rodrigo
    Alienware-Rodrigo Company Representative
    Hi,
    For hardware repairs, send us your Service Tag by email at awsocialmedia@dell.com. We will be glad to assist you.
