Alienware 17 R4 fan noise worse after bios update
Discussion in 'Alienware' started by mordynl, Aug 28, 2017.
  1. mordynl
    mordynl Newbie
    HI all,
    I have an Alienware 17 R4 that had its motherboard and cooling system(Generation 2) replaced last month. Cooling is fine but since last bios update from dell the fans startup faster and make more noise just like before replacement. Is there anyone who has the same problem?
    Temps are great CPU is at 60 \ 70 and GPU is 50\60. I know that a laptop makes more noise under load but this is like playing on helicopter :(
    Thanks in advance!
  2. Wormwood
    Wormwood Notebook Evangelist
    The BIOS updates usually change the fan curve.
  3. Maineiac12
    Maineiac12 Notebook Evangelist
    Is CPU performance mode on or off?
  4. mordynl
    mordynl Newbie
    I checked in the bios and this is off. What i found out yesterday that when i game for like 3 hours the keyboard just gets hotter and hotter but it still says my temps are great.
  5. Wormwood
    What are you using to monitor temperatures?
    Also, check your PCH and SSD Temperatures as those are usually what heat up the palmrest and keyboard.
  6. mordynl
    mordynl Newbie
    I will check that i use HWinfo to monitor my temps.
  7. mordynl
    mordynl Newbie
    Temps are good on PCH and SSD. I had contact with Dell en the man on the phone said to go back to bios 1.1.8 but still then the fans turn on louder then before. He said it will be a bios update but i dont buy it i will be called later this week on what were gonna do. Anyone have other suggestions and is there no one with the same problem here on the forum?
    thanks for you feedback so far!
